您好,我有一个问题关于错误的温度传感器使用在Mb39 C811(能量收集启动器套件)。它显示-46C与0%的相对湿度无关的外部温度。有谁知道哪部分出错了??
以上来自于百度翻译 以下为原文 Hello, I have a question on incorrect reading of the temperature sensor used in MB39C811 (Energy Harvesting Starter Kit). It shows -46C with 0% relative humidity regardless of the outside temperature. Does anyone know which part went wrong?? |
3个回答
你好,Kato,
你能解释一下如何检查温湿度传感器的输出吗? 谢谢, Yuva。 以上来自于百度翻译 以下为原文 Hello Kato-san, Can you explain how you check the output of temperature and humidity sensor? Thanks, Yuva. |
嗨,Yuva, 非常感谢您的回复! 我在台灯下测试了室温(~28℃)的温度。 正在阅读-46C。 当我不允许光到达太阳能电池时,读数停止。 (所以我假设交流工作正常) 接下来,我带他们去冰箱看看温度是否升高。 减少。但它仍然在读-46C。 我非常感谢你的帮助。 最好的问候, 基科 2018年4月17日下午12点19分,YVA & LT社区经理@ CyPress .com & GT; 以上来自于百度翻译 以下为原文 Hi Yuva, Thank you very much for your reply ! I tested the temperature under desk lamp at room temperature (~28C) and it was reading -46C. When I do not allow the light to reach the solar cell, the reading stops. (So I assume communication is working properly) Next, I took them to fridge to see if the temperature increases or decreases. But it was still reading -46C. I would really appreciate your help. Best Regards, Keiko On Tue, Apr 17, 2018 at 12:19 AM, yuva <community-manager@cypress.com> |
嗨,Keiko san, 你如何观察温度和湿度传感器的变化,你是否遵循KIT指南第4.2节中的步骤?在iOS或Android中使用什么应用程序?你能查一下替代申请吗?这个问题可能是由于温度和湿度传感器不工作或某种类型的通信问题。还确保降压转换器(Mb3C811)的输出处于稳定电压。 谢谢, Yuva。 以上来自于百度翻译 以下为原文 Hi Keiko-san, How do you observe the changes on the temperature and humidity sensor, do you follow the steps in section 4.2 in kit guide. What application in iOS or Android is used? Can you check with the alternative application? The issue could be due to temperature and humidity sensor not working or some type of communication issue. Also ensure the output of the Buck converter (MB39C811) is at stable voltage. Thanks, Yuva. |
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1600 浏览 1 评论
1000浏览 2评论
665浏览 2评论
511浏览 2评论
479浏览 2评论
1351浏览 2评论
GMT+8, 2025-4-6 22:48 , Processed in 1.430109 second(s), Total 79, Slave 63 queries .
