我有一个设计,生成一堆以下消息:错误:包:1107 - 包无法将下面列出的符号组合成单个IOB组件,因为所选的站点类型不兼容。但他们没有进一步的信息说明哪些符号
。 我还有一堆尚未连接的符号。 是否由于断开/未使用的符号而显示这些错误? 如果是这样,我该怎么办才能让他们不再使用但仍然没有错误通过? 以上来自于谷歌翻译 以下为原文 I have a design that's generating a bunch of the following messages: ERROR:Pack:1107 - Pack was unable to combine the symbols listed below into a single IOB component because the site type selected is not compatible. But they have no further information stating which symbols. I also have a bunch of symbols that are not yet connected. Is it showing these errors because of the disconnected/unused symbols? If so, what can I do to leave them unused but still pass with no errors? |
5个回答
如果您在导航器GUI的“错误”选项卡中查看错误,您应该知道只有
该选项卡中显示错误消息的第一行。 您需要查看报告文件(在本例中) 我假设它是地图报告)找到错误的全文。 - Gabor 以上来自于谷歌翻译 以下为原文 If you're viewing the error in the "Errors" tab of the Navigator GUI, you should be aware that only the first line of an error message shows up in that tab. You need to look at the report file (in this case I'm assuming it's the Map report) to find the full text of the error. -- Gabor |
如果您有悬挂输入/输出缓冲区限制在GT IPAD / OPAD站点,这将是预期的。
这些工具需要GT连接来确定应该使用IPAD / OPAD而不是IOB。 由于站点类型不匹配,IOB将触发Pack:1107。 以上来自于谷歌翻译 以下为原文 If you have dangling input/output buffers constrained to GT IPAD/OPAD sites this would be expected. The tools needs the GT connectivity to figure out that an IPAD/OPAD should be used instead of an IOB. The IOB will trigger a Pack:1107 due to the site type mismatch. |
在我知道大部分意思之前,我想我还有很多东西需要学习。
我可以告诉你,我没有将任何悬空信号添加到我的用户约束文件中。 它们是否可以限制在其中一个LEON文件中的GT IPAD / OPAD站点? 以上来自于谷歌翻译 以下为原文 I guess I have a lot more to learn before I know what most of that means. I can tell you that I didn't add any of those dangling signals to my user constraints file. Could they be constrained to GT IPAD/OPAD sites in one of the LEON files? |
没有完整的错误消息很难说你的问题是什么。
Pack:1107错误是IO打包问题的全部错误,可能由于多种原因而发生。 由于我以前的回答没有引起你的共鸣,这个问题可能很容易成为别的问题。 以上来自于谷歌翻译 以下为原文 Hard to say what your problem is without the full error message. The Pack:1107 error is a catch-all error for IO packing issues and can occur for many reasons. Since my previous response didn't resonate with you, the problem could easily be something else. |
您使用的ISE版本是什么?
在ISE 11.4中有一个回归,其中打印错误没有详细信息。 http://www.xilinx.com/support/answers/34270.htm 如果是这种情况,请尝试在12.1和abve(或返回到11.3)中运行以查看所涉及的符号。 -------------------------------------------------- -----------------------不要忘记回答,kudo,并接受为解决方案.------------- -------------------------------------------------- ---------- 以上来自于谷歌翻译 以下为原文 What ISE version are you using? There was a regression in ISE 11.4 where the error is printed without detailed information. http://www.xilinx.com/support/answers/34270.htm If this is the case, try running in 12.1 and abve (or back to 11.3) to see the symbols involved. ------------------------------------------------------------------------- Don't forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
2694 浏览 7 评论
3013 浏览 4 评论
2433 浏览 9 评论
3539 浏览 0 评论
2636 浏览 15 评论
3422浏览 1评论
835浏览 1评论
697浏览 1评论
GMT+8, 2025-7-6 07:08 , Processed in 1.305052 second(s), Total 55, Slave 49 queries .
