Using LEDs for front lighting provides multiple advantages. Not only weight reduction and CO2 savings, but also better control of the areas to light up, as well as various shapes which make the car OEM easy to recognize. Pixel Light solutions or Matrix Beam avoid glaring oncoming drivers while using the high beam to optimize the driver’s visibility and thus increasing the safety for all road users.
There are two main topologies for Matrix Beam: Parallel Drive and Serial Drive. Figure 1: Serial Topology. Every string has multiple LEDs in series allowing higher voltages.
Figure 2: Parallel Topology. Every single LED has a current sink, easing the cooling of the LEDs through a common anode.
The main benefit of parallel driving is the LEDs have a common anode pin, which helps the heat transport from the LED-chip to the heatsink in the very special case that multiple LED-chips are in the same LED package. Nevertheless this occasional advantage does not compensate for the many disadvantages which are related to parallel drive. The solution requires a single current source per LED. While taking the complete system under consideration the heat sink required for parallel driving is bigger due to the increased power loss in linear current sinks required for this topology.
The benefits of a serial topology outnumber the costs of the LED cooling: a single current source per string, and the parallel switches do not dissipate additional power when the LED is active. There is also intrinsic current matching for all the LEDs and no need for selecting LEDs with matching forward voltage. This topology allows using higher voltages and less conversion losses. Serial drive gives a higher modularity being compatible with pixel light solutions as well as non-pixel light.
Figure 3: NCV78763: Power Ballast and Dual LED Driver for Automotive Front Lighting 2nd gen / 1.6A
Use the comment section below to share your opinion!
What do you think about parallel drive vs. serial drive? Which solution do you see pushing through in the market?
