你好,
我想知道如何打开另一个端口进行mavlink连接...我知道默认情况下连接是在端口5760上,但是我希望有另一个像5762端口。 目的是我有一个在Intel aero rtf内部运行的脚本,该连接位于tcp:127.0.0.1:5760然后,我想从我的PC发送另一个脚本。 以上来自于谷歌翻译 以下为原文 Hi there, I wonder how can I open another port for mavlink connection... I know that by default the connection is on port 5760, but I want to have another like 5762 port. The purpose is that I have a script running inside the Intel aero rtf which connection is at tcp:127.0.0.1:5760 and then, I want to send another script from my PC. |
您好ivanalexo,感谢您对Intel Aero Ready to Fly Drone的兴趣。关于您打开mavlink连接的另一个端口的问题,我发现以下github帖子可能会有所帮助:https://github.com/
intel / mavlink-router / issues / 122让我知道这些信息是否有用,或者我是否可以为您提供其他任何帮助。最好的问候,Casandra 以上来自于谷歌翻译 以下为原文 Hello ivanalexo, Thank you for your interest in the Intel Aero Ready to Fly Drone. In regards to your query about opening another port for the mavlink connection, I found the following github post that might be helpful: https://github.com/intel/mavlink-router/issues/122 Let me know if this information proves useful or if I can assist you with anything else. Best regards, Casandra |
jerry1978 发表于 2018-10-15 19:12 谢谢你的回答,我也检查了这些信息,但它没有帮助我...... 我尝试配置mavlink-router的main.conf添加TCP客户端,但它也不起作用: [TcpEndpoint delta] 地址= 127.0.0.1 港口= 5762 RetryTimeout = 10 以上来自于谷歌翻译 以下为原文 Thanks for your answer and I also checked that info but it didn't help me... I try to configure main.conf of mavlink-router adding a TCP Client but it also didn't work: [TcpEndpoint delta] Address = 127.0.0.1 Port = 5762 RetryTimeout = 10 |
GMT+8, 2025-7-6 06:51 , Processed in 0.755743 second(s), Total 76, Slave 60 queries .
