嗨,我正在尝试设置一个实验来测量处理过程中设备的电流。
我想从设备发送一个触发器到DMM,以便在给定时间开始测量。 我无法找到用于触发输入的正确设置,即触发脉冲应使用的电压,脉冲的最小长度是多少。 一旦完成处理,是否可以停止测量? 处理所需的时间长度会有所不同,所以我只能为数字万用表设置一个预先计算的读数。 以上来自于谷歌翻译 以下为原文 Hi, I am trying to setup an experiment to measure the current of a device during processing. I would like to send a trigger from the device to the DMM to start the measurement at a given time. I am not able to find the correct settings to use for the trigger input i.e what voltage i should use for the trigger pulse, what is the minimum length of the pulse. also, would it be possible to stop the measurements once i am done with the processing? The length of time required for processing will vary so i cant just set a precalculated number of readings for the DMM. |
1396 浏览 0 评论
2424 浏览 1 评论
2275 浏览 1 评论
2113 浏览 5 评论
3028 浏览 3 评论
1494浏览 1评论
840浏览 0评论
1257浏览 0评论
1397浏览 0评论
GMT+8, 2025-3-7 00:34 , Processed in 1.281674 second(s), Total 73, Slave 57 queries .
