HI团队我使用S29 ALL 016J为我的项目,我有问题下载代码到它,我已经创建了一个闪存ALGO,但每当它给一个闪光灯超时错误,你能帮助我在这一点。
你能分享任何你所需要的ALGO吗? 我在追随我的目标。 闪光灯 1.2 K 闪光灯 1.8 K 以上来自于百度翻译 以下为原文 Hi Team I am using S29AL016J for my project and I have problems downloading the code into it, I have created a Flash Algo but everytime it give a Flash time out error,Could you please help me out in this. Could you share any algo you have for reference. I am attaching my algo.
3个回答
你好,
下面我来问几个问题。 1)你试过AutoSead命令并得到预期的制造商/设备ID吗? 2)当你说“闪存超时错误”时,它是否意味着Delphi()函数中的DQ5=1,或者外部定时器决定超时? 3)FLASPRG C中的哪一个函数导致错误、擦除芯片、擦除器和/或程序页? 最好的问候, 尊礼 以上来自于百度翻译 以下为原文 Hello, Let me ask some questions below. 1) Did you try the Autoselect commands and get expected Manufacturer/Device ID? 2) When you said "a Flash time out error", does it mean DQ5=1 in the Polling() function or an external timer determines timeout? 3) Which function(s) in your FlashPrg.c results in the error, EraseChip, EraseSector, and/or ProgramPage? Best Regards, Takahiro |
非常感谢您的支持和抱歉的延迟响应,因为我正在调试硬件。
我能根据数据表读取芯片ID。 它读取制造ID:01 设备ID:2249(底部引导和Word模式) 但我仍然无法将代码转入芯片中。 你能帮帮我吗? 以上来自于百度翻译 以下为原文 Hi thanks a lot for the support and sorry for the delay response, as I was debugging the Hardware. I was able to read the chip ID as per the data sheet and it reads the Manufacture ID : 01 Device Id : 2249 ( Bottom Boot and in Word mode) But still I am not able to dump code into the chip. Could you help me out for the same. |
你好, 由于您可以读取正确的ID,主机和闪存之间的连接就可以了。 你对下面两个问题有什么看法吗? 2)当你说“闪存超时错误”时,它是否意味着Delphi()函数中的DQ5=1,或者外部定时器决定超时? 3),功能(S)在你的flashprg。C结果的误差,erasechip,erasesector,和/或programpage? 最好的问候, 尊礼 以上来自于百度翻译 以下为原文 Hello, Since you can read the correct ID, the connection between the host and flash is OK. Do you have any observations about other two questions below? 2) When you said "a Flash time out error", does it mean DQ5=1 in the Polling() function or an external timer determines timeout? 3) Which function(s) in your FlashPrg.c results in the error, EraseChip, EraseSector, and/or ProgramPage? Best Regards, Takahiro |
762个成员聚集在这个小组
加入小组2181 浏览 1 评论
1928 浏览 1 评论
3749 浏览 1 评论
1851 浏览 6 评论
1596 浏览 1 评论
824浏览 2评论
638浏览 2评论
508浏览 2评论
472浏览 2评论
1341浏览 2评论
GMT+8, 2025-3-31 12:50 , Processed in 1.224781 second(s), Total 81, Slave 65 queries .
