在ISE工具中运行Translate时,我收到以下几个错误:ERROR:NgdBuild:467 - 输出垫网'FPGA_0_ddr2_clk_0_OBUF'有一个非法缓冲区ERROR:NgdBuild:467 - 输出垫网'fpga_0_ddr2_clk_1_OBUF'有一个非法缓冲区......
错误:NgdBuild:947 - bidirect pad net'fpga_0_ddr2_dq_0_OBUF'正在驱动非输入缓冲区:块上的引脚I fpga_0_ddr2_dq_0_OBUF类型为OBUFERROR:NgdBuild:947 - bidirect pad net'fpga_0_ddr2_dq_10_OBUF'正在驱动非输入缓冲区 :针对类型为OBUF的块fpga_0_ddr2_dq_10_OBUF上的引脚I ...为什么我会看到这些错误,以及如何解决它们? 我试过http://www.xilinx.com/support/answers/32847.htm但它不起作用。 我可以得到一些帮助吗? 谢谢, 拉夫 以上来自于谷歌翻译 以下为原文 When running Translate in the ISE tools, I receive several of the following errors: ERROR:NgdBuild:467 - output pad net 'fpga_0_ddr2_clk_0_OBUF' has an illegal buffer ERROR:NgdBuild:467 - output pad net 'fpga_0_ddr2_clk_1_OBUF' has an illegal buffer... ERROR:NgdBuild:947 - bidirect pad net 'fpga_0_ddr2_dq_0_OBUF' is driving non-input buffer(s): pin I on block fpga_0_ddr2_dq_0_OBUF with type OBUF ERROR:NgdBuild:947 - bidirect pad net 'fpga_0_ddr2_dq_10_OBUF' is driving non-input buffer(s): pin I on block fpga_0_ddr2_dq_10_OBUF with type OBUF... Why do I see these errors, and how can they be resolved? I have tried http://www.xilinx.com/support/answers/32847.htm but it does not work. Can I get some help on this? Thanks, Gaurav |
在ISE工具中运行Translate时,我收到以下几个错误:ERROR:NgdBuild:467 - 输出垫网'fpga_0_ddr2_clk_0_OBUF'有一个非法缓冲区ERROR:NgdBuild:467 - 输出垫网'fpga_0_ddr2_clk_1_OBUF'有一个非法缓冲区......
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2625浏览 1评论
670浏览 1评论
535浏览 1评论
821浏览 0评论
GMT+8, 2025-3-6 19:07 , Processed in 1.362817 second(s), Total 44, Slave 39 queries .
