在我的Virtex 5上,64位版本的ISE 13.2中的布局和布线完成,但失败了。
但是,同样的步骤适用于32位版本。 为了减少在32位和64位版本之间切换的需要,我该如何调试呢? 以上来自于谷歌翻译 以下为原文 On my Virtex 5, Place and Route in the 64-bit version of ISE 13.2 finishes, but fails. However, the same step works in the 32-bit version. To alleviate the need to switch between the 32- and 64-bit versions, how can I debug this? |
您可以比较不同放置阶段的校验和值,以查看两次运行的分歧。
如果第一个校验和不同,那么问题就在于放置的上游。 如果最后一个校验和相同,但您在摘要中获得了不同的利用率,那么它就是放置的下游。 如果要在计算机之间复制项目文件,请确保未运行具有时间戳依赖性的ngdbuild。 以上来自于谷歌翻译 以下为原文 You can compare the checksum values at the various placement phases to see where the two runs diverged. If the first checksum is different then the problem is upstream of placement. If the last checksum is the same but you get different utilization in the summary, then it's something downstream of placement. If you are copying the project files between machines make sure that you are not running ngdbuild with time stamp dependency. |
嗨,
如前一篇文章中所述,尝试在ngd构建命令行属性中使用switch -nt on。 另请查看链接http://www.xilinx.com/support/answers/23904.htm,这对您的情况很有用,因为在不同的环境中运行是不同的,即32位和64位。 谢谢 Anirudh 谢谢,AnirudhPS:请将此标记作为答案,以防它有助于解决您的问题。如果帖子引导您找到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, As mentioned in the previous post try using the switch -nt on in ngd build command line properties. Also check the link http://www.xilinx.com/support/answers/23904.htm which can be useful for your case, since the run is different in different environments i.e 32 bit and 64 bit. Thanks Anirudh Thanks, Anirudh PS: Please MARK this as an answer in case it helped resolve your query.Give kudos in case the post guided you to a solution. |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2627浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 01:17 , Processed in 1.376205 second(s), Total 79, Slave 63 queries .
