扫一扫,分享给好友
下午好,
我无法关闭PCIE Intel 905P的LED。 我试图使用命令行,但它是唯一给我“无效参数”的命令,但我不知道为什么。 请你帮助我好吗? 非常感谢! 以上来自于谷歌翻译 以下为原文 Good afternoon, I am having trouble to switch off the LED fo the PCIE Intel 905P. I am trying to use the command line, but it is the only command that give me "Invalid arguments" but I don't know why. Could you please help me? Thanks a lot! |
4个回答
您好fabiol,感谢您联系英特尔®威廉希尔官方网站
支持。
据我们了解,您需要有关英特尔®Optane™SSD 905P系列的帮助。 如果我们正确推断并为了进一步为您提供帮助,请查看并考虑以下信息:以下步骤描述了如何更改LED状态: 1.安装最新版本的英特尔®固态硬盘工具箱(必须为3.5.3或更高版本)。 2.查找并将路径*复制到英特尔SSD工具箱应用程序。*路径可能因计算机而异。 打开命令提示符并导航到Intel SSD Toolbox文件夹.-您可以使用以下命令(使用cd C: ..)作为示例:4。执行以下命令(包括引号):a)“Intel SSD工具箱“.exe -drive_index#-led_color?b)将#替换为磁盘管理中显示的驱动器号c)替换? 使用以下之一: - 绿 - 红 - 蓝 - 开 - 例如:5。 执行命令后,命令提示符将通知操作是否成功。 如果您按照这些步骤仍然遇到任何问题,请向我们提供错误的屏幕截图。 我们希望您发现此信息有用。 最好的祝福, JoshB.Intel®客户支持威廉希尔官方网站 人员与英特尔公司签订合同 以上来自于谷歌翻译 以下为原文 Hello fabiol, Thank you for contacting Intel® Technical Support. As we understand, you need assistance with your Intel® Optane™ SSD 905P Series. If we infer correctly and in order to further assist you, please, review and take into consideration the following information: The following steps describe how to change the LED status: 1. Install the latest version of Intel® Solid State Drive Toolbox (must be 3.5.3 or later). 2. Find and copy the path* to the Intel SSD Toolbox application. * The path may be different depending on the computer. 3. Open the Command Prompt and navigate to the Intel SSD Toolbox folder. - You can use the following command (using cd C:..) as an example: 4. Execute the following command (including the quotation marks): a) "Intel SSD Toolbox".exe -drive_index # -led_color ? b) Replace # with the number of the drive as it shows up in Disk Management c) Replace ? with one of the following: - green - red - blue - off - on Example: 5. The command prompt will notify if the operation was successful after executing the command. If by following these steps you still experience any issue, please, provide us with a screenshot of the error. We hope you find this information helpful. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation |
您好fabiol感谢您的回复。为了进一步帮助您,我们需要您提供以下基本信息: 您当前安装在Intel®Optane™SSD 905P系列中的固件版本。 SSU记录。 1-访问https://downloadcenter.intel.com/download/26735/并下载该软件。 2-完成下载后,打开它。 3-将获得的文件附加到您的回复中。 来自Intel®Optane™SSD 905P系列的SMART details.CSV文件(SMART日志)。 在“IntelSolidStateDriveToolboxUserGuide.pdf”第3.2节中,您可以找到有关如何获取此文件的说明。我们期待您的回复。最好的问候,JoshB.Intel®客户支持威廉希尔官方网站 人员与英特尔公司的合同 以上来自于谷歌翻译 以下为原文 Hello fabiol Thank you for your reply. In order to further assist you we need you to provide us with the following basic information:
We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation |
jerry1978 发表于 2018-10-12 18:59 你好Josh! 在这里,您附上了所请求的文件,并按照固件编号。 FIRMWARE E2010420 希望很快能收到你的好消息! 谢谢,最好的, - FL Fabio Liberati系统信息20181010.txt.zip 6.6 K. Fabio Liberati Intel 905p SMART.csv.zip 2.6 K. 以上来自于谷歌翻译 以下为原文 Hello Josh! Here you are attached the file requested, and following the firmware number. FIRMWARE E2010420 Hope to hear from you good news soon! Thanks and best, - FL
519浏览 0评论
GMT+8, 2024-12-25 12:57 , Processed in 0.658637 second(s), Total 86, Slave 69 queries .
