嗨,
我在两台不同的电脑上试过这张卡: - 一个带有集成Realtek RTL8111E芯片的MSI Z87-G43主板 - 带有集成Intel I217-LM以太网芯片的Dell EliteDesk 800 G1 PC 在每种情况下,它都表现完全相同,运行Windows 10 64位或Debian GNU / Linux(4.18.0-1-amd64):局域网唤醒在集成上运行良好 控制器,它不适用于英特尔千兆CT台式机适配器。 我试过禁用集成控制器,我已经确定了PCI-E 我已经在UEFI设置工具中正确设置了唤醒和S5唤醒选项 尝试了多个BIOS / UEFI固件版本,包括最新版本。 我还尝试了英特尔BootUtil工具中的所有可能选项(确保WoL 启用,尝试每个可用的Option ROM(PXE / UEFI / Combo)。 在每种情况下,我都有相同的结果:千兆CT上的链路断开 系统进入暂停或关闭状态后即可使用适配器,并且无法唤醒 通过这个界面,但另一个工作(当然,除非禁用)。 那么,WoL实际上应该工作吗? 有什么我忽略的吗? 我还能尝试别的吗? 提前致谢, 亚历克斯 以上来自于谷歌翻译 以下为原文 Hi, I have tried this card on two different computers: - one with a MSI Z87-G43 motherboard with an integrated Realtek RTL8111E chip - a Dell EliteDesk 800 G1 PC with an integrated Intel I217-LM Ethernet chip In each case, it behaved exactly the same, running Windows 10 64bit or Debian GNU/Linux (4.18.0-1-amd64) : Wake-on-LAN works fine on the integrated controller, and it does not work on the Intel Gigabit CT Desktop Adapter. I have tried disabling the integrated controller, I have made sure PCI-E wake up and S5 wake up options were set properly in the UEFI setup tool, I have tried multiple BIOS/UEFI firmware versions, including latest available. I also tried every possible option in the Intel BootUtil tool (made sure WoL is enabled, tried every available Option ROM (PXE/UEFI/Combo). And in each case, I have the same result: link goes down on the Gigabit CT Adapter as soon as the system goes to suspend or shutdown, and cannot be woken up through this interface, but the other one works (unless disabled, of course). So, is WoL actually supposed to work ? Is there something I overlooked ? Something else I could try ? Thanks in advance, Alex |
您好Pipomolo42,感谢您发布在英特尔有线以太网社区。
请检查“设备管理器”中CT适配器的“电源管理”选项卡下是否启用“允许此设备唤醒计算机”,因为默认情况下未启用它。 对于Debian,可能会有类似的命令。 请在Windows中尝试上述步骤,并为Debian提供ethtool,ethtool -i和ethtool -k。 如果您有任何疑问,请告诉我们。最好的问候,Daniel DIntel客户支持 以上来自于谷歌翻译 以下为原文 Hello Pipomolo42, Thank you for posting in Intel Wired Ethernet Communities. Please check if "allow this device to wake the computer" is enabled under "Power Management" tab of the CT adapter in Device Manager, as it is not enabled by default. For Debian there may be a similar command. Please try the above steps in Windows, and provide ethtool Best regards, Daniel D Intel Customer Support |
520浏览 0评论
GMT+8, 2024-12-26 00:20 , Processed in 0.454588 second(s), Total 48, Slave 42 queries .
