如果我将硬盘驱动器分为2TB + 2TB或1TB * 4,是否有任何问题?
以上来自于谷歌翻译 以下为原文 Is there any problem that if i divide my harddisk drive 2TB+2TB or 1TB*4? |
您好LegendH,感谢您在英特尔®社区发布。在不同的分区中划分驱动器不建议使用,实际上,它不是支持的英特尔®Optane™内存配置,特别是如果您计划在驱动器中安装另一个操作系统
。我建议你继续使用一个分区使用你的驱动器,这样英特尔®Optane™内存就可以保持正常工作。我希望这些信息可以解答你的问题。 如果还有什么我可以帮到你,请告诉我。祝你有个美好的一天。感谢,Diego V. 以上来自于谷歌翻译 以下为原文 Hi LegendH, Thank you for posting in the Intel® communities. Dividing the drive in different partitions it’s not recommended and actually, it’s not a supported configuration for the Intel® Optane™ Memory, especially if you are planning to install another OS in the drive. I recommend you to keep using your drive with one single partition so the Intel® Optane™ Memory can keep working correctly. I hope this information answers your question. Please let me know if there is anything else I can help you. Have a nice day. Regards, Diego V. |
GMT+8, 2025-2-24 17:01 , Processed in 0.649571 second(s), Total 74, Slave 58 queries .
