使用STM32做ADC电流采样,4通道,发现当只有一个通道输入电流和四个通道都有电流输入的时候,采样结果会有差异。比如通道1输入3mA电流,其它通道都输入0mA,这时候1通道采样值为2.975mA,当1通道输入仍为3mA,其它通道都输入20mA,这时候的1通道采样值为2.896mA.检测过运放输出端的电压在两种情况下都没有发生改变,采样值却发生了改变。
有没有哪位大神解决过这样的问题? 驱动代码如下,理论上驱动代码应该不会有问题的 ADC_InitTypeDef ADC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; ADC_DeInit(ADC1); //ADC1 DeInit RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE); //ADC1 Periph and GPIOC Periph clock enable GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;//Configure ADC Channel 10-13 as analog input GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOC, &GPIO_InitStructure); /* ADC1 configuration ------------------------------------------------------*/ ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode = ENABLE; ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel = 4; ADC_Init(ADC1, &ADC_InitStructure); ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_55Cycles5); ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 4, ADC_SampleTime_55Cycles5); ADC_DMACmd(ADC1, ENABLE); //Enable ADC1 DMA ADC_Cmd(ADC1, ENABLE); // Enable ADC1 ADC_ResetCalibration(ADC1); //Enable ADC1 reset calibration register while(ADC_GetResetCalibrationStatus(ADC1)); //Check the end of ADC1 reset calibration register ADC_StartCalibration(ADC1); //Start ADC1 calibration while(ADC_GetCalibrationStatus(ADC1)); //Check the end of ADC1 calibration ADC_SoftwareStartConvCmd(ADC1, ENABLE); //Start ADC1 Software Conversion DMA_InitTypeDef DMA_InitStructure; /* DMA1 clock enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1 , ENABLE); /* DMA1 Channel1 Config */ DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_Address; //ADC1->DR DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)ConvData_Tab; DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = ADC_TIMES_ALL ; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); /* DMA1 Channel1 enable */ DMA_Cmd(DMA1_Channel1, ENABLE); |
3个回答
没有一位兄弟遇到过吗?
你看看参考电压有没有影响,还不行的话第一次切换通道的数据作废,你试试
谢谢兄弟 参考电压用的参考电压芯片 测试了 没有变化了 用台表测试的 采集方式是循环采集 和 第几次才没有关系 采样结果都不变的
1365 浏览 0 评论
国产NSI1300D05-DSWVR放大芯片放大增益8.2或41的问题
1358 浏览 0 评论
STM32串口接受中断使用C++STL中的queue导致所有中断失效
8895 浏览 1 评论
3648 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1580 浏览 0 评论
GMT+8, 2025-3-7 01:13 , Processed in 0.812970 second(s), Total 47, Slave 41 queries .
