您好,BootRADER生成器在中断向量中写入跳跃。我不想使用Bootloader中的中断,因为我想避免中断跳跃。它是否与Bootloader生成器一起工作,或者我必须用脚踏写引导程序吗?
以上来自于百度翻译 以下为原文 Hello, the bootlader generator writes jumps in the interrupt vectors. I don't want to use the interrupts in the bootloader because I want to keep off the interrupt jumps. Does it work with the bootloader generator or do I have to write a bootloader by foot? |
4个回答
你有选择,但MCC不会为你建造。哪一张照片?
以上来自于百度翻译 以下为原文 You have options, but MCC will not build it for you. Which PIC? |
引导加载程序将跳入以反映高优先级和低优先级中断到NexyReStEyValth+ 8和+ 18。在构建应用程序时,应用偏移量将重置和中断向量移到引导加载程序的末尾,所有的内容都将匹配。参见Bootloader用户指南中的图5-5:HTTP:/WW1.MyCHCHIP.COM/Deloads/En/DeVICECD/OC017177B.PDF
以上来自于百度翻译 以下为原文 The bootloader will put in jumps to reflect the high and the low priority interrupts to NEW_RESET_VECTOR +8 and +18. When you build your application, apply an offset to move the reset and interrupt vectors past the end of the bootloader and everything will match up. See Figure 5-5 in the bootloader User's Guide: http://ww1.microchip.com/downloads/en/DeviceDoc/40001779B.pdf |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
484浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 19:45 , Processed in 1.157066 second(s), Total 51, Slave 46 queries .
