我不希望'ST time of Flight威廉希尔官方网站
使用光子探测器来测量产生的光脉冲离开我们的产品所需的时间,然后从目标反射并返回我们的设备。知道所需的时间,就可以知道光速来计算精确的距离测量值。
我的问题是:由于VL6180X计算距离作为发射和接收红外线之间的时间,它如何测量距离(例如约1cm),其对应于皮秒级的飞行时间? 谢谢 #vl6180x 以上来自于谷歌翻译 以下为原文 I undesratnd that ''ST Time of Flight technology uses photon detectors to measure the time it takes a generated light pulse to leave our product, then reflect from a target and come back to our device. Knowing the time it takes, an accurate distance measurement can be calculated knowing the speed of light.'' My question is: since VL6180X calculate the distance as the time between transmitting and receiveing the infrared, how can it measure distances (e.g. about 1cm) which correspond to a time of flight in the order of picoseconds ? Thanks #vl6180x |
答案是统计数据。有近百万个小脉冲光和一个相当复杂的统计算法来计算它。
- 约翰 以上来自于谷歌翻译 以下为原文 The answer is statistics. There are almost a million small pulses of light and a rather complex statistical algorithm to figure it all out. - john |
2769 浏览 1 评论
3249 浏览 1 评论
1821 浏览 1 评论
3664 浏览 6 评论
6056 浏览 21 评论
1346浏览 4评论
210浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
364浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
458浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
284浏览 2评论
GMT+8, 2025-1-6 13:24 , Processed in 1.042577 second(s), Total 71, Slave 65 queries .
