问候语!我将第一次使用USPIC32 MM25256GPM064。所以我正在创建我的PCB,但是我不知道哪一个引脚对应于MCCP的输出。我需要用5个MCCP模块产生5个PMW信号。那么这些信号应该放在哪里呢?我试过一个SIMOS,但没有运气。我需要帮助!谢谢!
以上来自于百度翻译 以下为原文 Greetings! I`m about to use PIC32MM0256GPM064 for a very first time. So I`m creating my PCB, but I can`t find out which pins correspond to MCCP outputs. I need to generate 5 PMW signals using 5 MCCP modules. So where these signals should be lead out? I`ve tried with a simos to find out but without any luck. I need assistance here! Thanks! |
4个回答
对!我看见了!但是这些引脚有什么信息吗?关于UC的信息说,应该有6个引脚与6个MCCP发电机。在MCCP部分有9套寄存器PMW。为什么有6个通道的3OCM集合?解释一下,请!谢谢!
以上来自于百度翻译 以下为原文 Yes! I saw it! But a little bit info about these pins?! The info about the uC says there should be 6 pins with 6 MCCP generators. In the MCCP section there are 9 sets of registers for PMW. Why there are 3 OCM sets with 6 channels each? Little bit explanation, pls! Thanks! |
模块1-3是MCCP模块,每个都有六个输出。模块4-9是SCCP模块,每个都有一个输出。SCCP的输出可以使用PPS进行重新映射。表14-1寄存器映射似乎有点故障,并且没有显示模块之间的差异(除了模块4)。设备头文件似乎是准确的。
以上来自于百度翻译 以下为原文 Modules 1-3 are MCCP modules, with six outputs each. Modules 4-9 are SCCP modules, with one output each. The SCCP outputs are remappable using PPS. The table 14-1 register map seems to be a bit buggy and doesn't show the differences between modules (except module 4). The device header files seem to be accurate. |
你可能会发现尝试使用MCC来建立这个芯片是很有趣的。我想你会发现别针是重新映射的。编辑:他把我打败了。
以上来自于百度翻译 以下为原文 You might find it interesting to try setting up this chip using MCC. I think you will find the pins are re map able. edit: he beat me to it smile |
5303 浏览 9 评论
2063 浏览 8 评论
1972 浏览 10 评论
3239 浏览 3 评论
2279 浏览 5 评论
826浏览 1评论
715浏览 1评论
663浏览 1评论
716浏览 0评论
615浏览 0评论
GMT+8, 2025-1-22 18:46 , Processed in 1.170851 second(s), Total 82, Slave 66 queries .
