如果您创建一个项目,然后尝试使用“Project | Open”打开它,它将加载,但是当您尝试编程程序存储器时,您会收到“编程失败”消息。如果你然后关闭STVP&重新启动它,您可以通过Project | 1(以前使用的项目)加载项目,它加载OK&将一切都编程好。
另一个长期存在的问题 - 文件名以绝对路径存储在项目文件中。这意味着如果不手动编辑.stp文件,则无法分发项目。然后,当您使用上面的解决方法时,它们将无法工作。 我不确定这个编程错误是否适用于ST7 - 没有时间尝试它。使用STICE-SWIM和STM8在STM8上失败RLINK游泳 JDF [此消息由以下人员编辑:jdf2525于09-05-2008 21:04] 以上来自于谷歌翻译 以下为原文 If you create a project and later try to open it by using ''Project|Open'' it will load but when you try to program Program Memory you get a ''Programming failed'' message. If you then close STVP & restart it, you can load the project via Project|1 (previously used projects) it loads OK & will program everything OK. An additional issue that's a long standing irritant of mine - file names are stored in the project files with absolute paths. This means that projects cannot be distributed without editing the .stp file by hand. And then they won't work when you use my workaround above. I'm not sure if this programming error applies to ST7 - haven't had time to try it. Fails on STM8 with STICE-SWIM & RLINK-SWIM jdf [ This message was edited by: jdf2525 on 09-05-2008 21:04 ] |
你好jdf,
您描述的问题实际上是已知的,并且已确定根本原因。将很快发布一个新版本的STVP(几周),这个问题将得到解决,不再需要解决方法。 我还在检查绝对文件名存储。我会及时通知你的。 亚历山大 [此消息由以下人员编辑:alexanderc于13-05-2008 10:45] 以上来自于谷歌翻译 以下为原文 Hello jdf, the issue you describe is in fact known and the root cause has been identified. There will be a new version of STVP to be issued soon (a couple of weeks) where this problem will be solved and the workaround will no longer be needed. I am still checking for the absolute filename storage. I'll keep you updated. Alexander [ This message was edited by: alexanderc on 13-05-2008 10:45 ] |
嗨jdf,
这是一个更新:新工具包将在6月中旬左右推出。 我已经向工具部门报告了绝对/相对文件名的问题。这个需要更长的时间才能解决。尚未承诺。 最好的祝福 亚历山大 以上来自于谷歌翻译 以下为原文 Hi jdf, here is an update: The new pack of the tools will be available around mid June. I have reported the issue with the absolute/relative file names to our tools department. This one will take a little bit longer to resolve. Not yet committed. Best Regards Alexander |
2783 浏览 1 评论
3252 浏览 1 评论
1826 浏览 1 评论
3672 浏览 6 评论
6065 浏览 21 评论
1350浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-13 18:49 , Processed in 1.183214 second(s), Total 79, Slave 63 queries .
