将为PIC24HJ16GP304处理器编写的代码在PIC24HJ64 GP204处理器上无需修改吗?
以上来自于百度翻译 以下为原文 Will code written for the PIC24HJ16GP304 processor work without modification on the PIC24HJ64GP204 processor? |
依赖于芯片的代码需要对PIN分配等进行调整,并且必须检查RAM的使用是否兼容。但是大多数代码可能工作得很好。
以上来自于百度翻译 以下为原文 The chip type dependent code needs adjustments for pin assignments etc. And you have to check if your RAM usage will be compatible. But most of the code will probably work fine. |
如果不看这两个设备的数据表,我建议您比较您正在使用的外围设备(和振荡器)的各种寄存器,以及配置设置。如果新处理器中有额外的“工作”位(表示一些额外的功能),以及它们的默认设置是什么,以及它们会产生什么样的影响,它们将显示给您。一般来说,控制和状态寄存器的默认设置是每个位为“0”,其具有功能性TU。关闭。因此,如果你的原始代码在这些寄存器中设置了特定的位,那么你应该是可以的,但是如果你同时设置整个寄存器,那么你需要检查你还没有打开一些你不想要的功能。如果您用配置位来保护内存,那么它们可能需要进行调整以适应内存保护默认设置通常是“未保护”的。此外,如果使用的是处理器特定的内存边界(例如,某些设备有特定的内存范围为DMA留出),那么这些也需要检查。
以上来自于百度翻译 以下为原文 Without looking at the data sheets for the two devices,I would suggest that you compare the various registers for the peripherals (and oscillator) that you are using, as well as the config settings. They will show you if there are extra 'working' bits in the new processor (that represent some additional functionality) and what their default setting is and what impact that will have. Generally the default settings for control and status registers is each bit is '0' which has the functionality turned off. Therefore if your original code sets the specific bits in these registers then you should be OK, but if you set the whole register at once, they you will need to check that you have not turned on some functionality that you didn't intend to. It seems that you are going to a device with more memory. If you are protecting that memory with the config bits then they will probably need to be adjusted to suit - the memory protection default setting is generally 'unprotected'. Also if you are using processor-specific memory boundaries (e.g. some devices had specific memory ranges set aside for DMA) then these will need to be checked as well. Susan |
5585 浏览 9 评论
2228 浏览 8 评论
2115 浏览 10 评论
3399 浏览 3 评论
2433 浏览 5 评论
1070浏览 1评论
899浏览 1评论
919浏览 1评论
947浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
644浏览 0评论
GMT+8, 2025-7-19 09:02 , Processed in 1.421981 second(s), Total 77, Slave 61 queries .
