我们使用的是Virtex-5 LX110T主板但无法让计算机识别该设备。
我们与JTAG访问连接。 在尝试对电路板进行编程时,我们收到了错误消息 “错误:iMPACT:583 - '1'从设备读取的IDCODE与BSDL文件中的IDCODE不匹配。 信息:iMPACT:1578 - '1':设备IDCODE:0000000000000000000000000000“ 我们尝试过不同的电缆,但它们都会导致相同的错误。 知道我们可能做错了什么吗? 以上来自于谷歌翻译 以下为原文 We're using a Virtex-5 LX110T board but can't get the computer to recognize the device. We connected with JTAG access. When trying to program the board, we got an error saying "ERROR:iMPACT:583 - '1' The IDCODE read from the device does not match the IDCODE in the BSDL file. INFO:iMPACT:1578 - '1': Device IDCODE : 0000000000000000000000000000" We've tried different cables but they all result in the same error. Any idea what we could be doing wrong? |
当通过碰撞或ChipScope正确识别JTAG电缆,但未正确读回设备ID代码时,这表明JTAG不正确。
假设您使用的电路板是Xilinx XUPV5-LX110T电路板,那么基本的JTAG链是正确的。 JTAG链中有一个选项可绕过/不绕过JTAG标头。 检查跳线J21的状态以确保您的设置正确。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 When the JTAG cable is correctly recognized by impact or ChipScope, but the device idcodes are not correctly read back then that is a strong indication that the JTAG is incorrect. Assuming that the board that you are using is the Xilinx XUPV5-LX110T board, the basic JTAG chain is correct. There is an option in the JTAG chain to bypass/not bypass the JTAG header. Check the state of jumper J21 to ensure that is correct for your setup. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2444浏览 1评论
658浏览 1评论
519浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 23:46 , Processed in 1.314722 second(s), Total 77, Slave 61 queries .
