嗨,
我正在使用“-detail”选项进行MAP,并在MAP结束时获得“按层次结构使用”报告。 在本报告中,顶层模块“ref_design_v5lxt250_x1”的LUT数量为24953! | 模块| 分区| 切片* | Slice Reg | 的LUT | ref_design_v5lxt250_x1 / | | 10824/24017 | 34/32136 | 37997分之24953 37997是总LUT,24953是属于此顶级模块的元素数。 24953是不可能的。 它只包括模块实例和一些逻辑。 任何人都可以告诉我这是如何发生的,并解决这个问题? 谢谢,Sythez Utilization_PLDA.txt 33 KB 以上来自于谷歌翻译 以下为原文 Hi, I'm doing MAP with "-detail" option and get a "Utilization by Hierarchy" report at the end of MAP. In this report, the number of LUTs of top module, "ref_design_v5lxt250_x1", is 24953 ! | Module | Partition | Slices* | Slice Reg | LUTs | ref_design_v5lxt250_x1/ | | 10824/24017 | 34/32136 | 24953/37997 37997 is total LUTs and 24953 is the number of elements belong to this top module. 24953 is impossible. It only include module instanciation and some logic. Can anyone tell me how this happens and how to solve this problem ? Thanks, Sythez |
我们有一个已知的问题,我们如何计算作为路由通过LUT或源常量创建的LUT。
目前,他们被计入顶级层次结构。 13.2将修复所涉及的连接并在其相关逻辑的层次结构中计算它们。 由于你的人数太高,这让我觉得还有其他问题。 您是否正在使用全球选择? 这可能导致在设计重新合成时在顶层创建逻辑。 以上来自于谷歌翻译 以下为原文 We have a known issue with how we count LUTs that are created as route-thru LUTs or to source constants. Currently they get counted in the top level hierarchy. A fix is coming for 13.2 to sniff out the connectivity involved and count them in the hierarchy of their related logic. Since your number is so high, it makes me think there are other issues. Are you using global opt for example? That might be causing logic to be created at the top level as the design is resynthesized. |
是的我使用-global_opt选项进行映射。
我没有这个选项重新映射项目,我得到减少的数字。 感谢您的帮助 以上来自于谷歌翻译 以下为原文 Yes I use -global_opt option for mapping. I re-mapped the project without this option and I get reduced numbers. Thank you for your help |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2626浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 00:39 , Processed in 1.526890 second(s), Total 79, Slave 63 queries .
