请帮助模型DSA91304A在A11(通道1和2)板更换后更改为DSO90804A ...安装的许可软件也无效... S / N MY48230015。
是否可以检索添加的软件的许可证? 最好的祝福! 德利奥 以上来自于谷歌翻译 以下为原文 Please help on Model DSA91304A was change to DSO90804A after A11 (channel 1 and 2) Board was replace... License software installed also not working... S/N MY48230015. Is it possible to retrieve the License for the added software? Best Regards! delio |
4个回答
对不起你遇到的问题我很抱歉。
您需要致电当地的威廉希尔官方网站 呼叫中心。 有关于如何购买示波器以及购买了哪些升级和许可证的记录。 人 以上来自于谷歌翻译 以下为原文 I'm sorry for the problems that you are having. You need to call your local Technical Call Center. There are records regarding how your scope was purchased, and what upgrades and licenses were purchased. Al |
HI Algos,谢谢,现在我正在联系我们的部门经理,希望得到一些信息。 我还要求提供本机上安装的特定软件的记录。 无论如何,我希望得到你们最快的支持......谢谢! 以上来自于谷歌翻译 以下为原文 HI Algos, Thanks, right now I am contacting our division manager from keysight and hope to get some info. I am also requesting for the records of the specific software that are installed on this unit. I was hoping to get the fastest support from you guys, anyway... Thanks! |
ncxs 发表于 2018-10-3 13:04 您应该注意免责声明,我帮助写了......我*加粗*相关的行“欢迎来到示波器论坛,这是一个来自世界各地的示波器用户的在线社区。论坛旨在成为一个地方 用户可以询问和回答其他用户的问题,交换想法,并分享使用Keysight示波器产品的提示和技巧。*论坛不是联系Keysight示波器威廉希尔官方网站 支持的最佳或主要方式。*请点击“联系专家 “在此页面上或访问Keysight示波器网站,以访问完整的产品文档,培训材料和广泛的应用程序库。” 此外,我个人签名,我通常使用... Al免责声明:为了更可靠的响应时间,您应该考虑致电当地的Keysight威廉希尔官方网站 呼叫中心。 Keysight论坛在“可用”的基础上进行监控,并不一定是解决威廉希尔官方网站 问题的最快方式。 以上来自于谷歌翻译 以下为原文 You should probably pay attention to the disclaimers, which I helped write... I *bolded* the relevant line "Welcome to the Oscilloscope forums, an online community of Oscilloscope users from around the world. The forums are designed to be a place for users to ask and answer other users’ questions, exchange ideas, and share tips and tricks for using Keysight Oscilloscope products. *The discussion forums are not the best or primary means to contact Keysight Oscilloscope Technical Support.* Please click on "Contact an Expert" on this page or go to the Keysight Oscilloscope Website to access complete product documentation, training materials, and an extensive library of applications." Also, to my personal signature, which I usually use... Al Disclaimer: For more reliable response times, you should consider calling your local Keysight Technical Call Center. The Keysight Forums are monitored on an "as available" basis, and aren't necessarily the fastest way to get technical questions answered. |
nvywyerwer 发表于 2018-10-3 13:14 嗨Al谢谢,并注意到! 问候! 德利奥 以上来自于谷歌翻译 以下为原文 Hi Al Thanks and well noted! Regards! delio |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3020 浏览 3 评论
1430浏览 1评论
827浏览 0评论
1197浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-25 04:04 , Processed in 1.340009 second(s), Total 81, Slave 65 queries .
