我们希望能够使用SD卡从电脑上使用USB和PSoC 5lp emfile组件。
有可能组合这两个组件吗?你过去有过这样的经历吗?如果可能的话,我们想获得一个样板工程。 以上来自于百度翻译 以下为原文 We would like to be able to operate SD card from PC using USB and emfile component in PSoC 5LP. Is it possible to combine these two components? Do you have such experience in the past? We would like to obtain a sample project if possible. |
4个回答
我们没有任何项目。但是我们有计划发布pSOC5LP USB作为USB Max存储类的代码示例。但是它会花一些时间。
谢谢, 希马 以上来自于百度翻译 以下为原文 We do not have any project. But we have plans to release code example for PSoC5LP USB enumerating as USB Massstorage class. However it would take some time. Thanks, Hima |
希玛桑 谢谢你的回复。 我知道,它需要两个组件,USB MSC和EMFLE,在PC上读取和写入SD卡。您是否计划发布一个结合它们的示例项目?或者仅仅是一个项目来读取和写入PSoC 5 LP闪存作为USB MSC? 以上来自于百度翻译 以下为原文 Hima-san, Thank you for your response. I understand that it requires two components, USB MSC and emfile, to read and write SD card on PC. Are you planning to release a sample project that combines them? Or is it simply a project to read and write PSoC 5 LP flash as USB MSC? |
wyfwer 发表于 2018-10-3 17:48 现在我们没有计划用EMPLE和USB发布项目。该计划是有一个项目,列举为USB MSC。 谢谢, 希马 以上来自于百度翻译 以下为原文 Right now we do not have plan to release a project with EmFile and USB. The plan is to have a project which enumerated as USB MSC. Thanks, Hima |
在本论坛中寻找我的SD卡和PSoC帖子。
不要使用emfile SD卡从柏树除非你为图书馆购买的源代码,因为它不能处理SD卡错误条件不锁psoc5 CPU。 以上来自于百度翻译 以下为原文 Look for SD Card and PSOC post(s) from me in this forum. Do not use the EMFILE sdcard from Cypress unless you purchase the source code for the library, as it cannot handle SD Card Error conditions without locking the PSOC5 cpu. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 17:12 , Processed in 0.835691 second(s), Total 50, Slave 45 queries .
