你好,
我在端点0x81a接收从P端口到U端口的数据,而通过这个DMA通道接收该数据,我不能通过端点0x01将U端口中的任何数据发送到控制中心的P端口通道,为什么? PTUU和UTOP通道都不能同时工作? 谢谢您。 以上来自于百度翻译 以下为原文 Hi, i am recieving data from p port to u port in the endpoint 0x81,while recieving this data through this dma channel,i am not able to send any data from u port to p port channel in the control centre through the endpoint 0x01.why? both ptou and utop channel will not work at a time? thank you. |
3个回答
你好,
是否将数据从P端口流到U端口? 你在UART打印上有什么错误? 还简要说明你的申请吗? 感谢和问候 Abhinav。 以上来自于百度翻译 以下为原文 Hi, Are you streaming continuous data from p port to u port? What error you are getting on UART print? Also explain your application in brief? Thanks & Regards Abhinav. |
你好, 我使用SLaveFIFO应用程序,我修改了控制中心。 我将连续数据从P端口流到端点0x81U端口,在流传输时,我将数据发送到控制中心端点0x01,即U端口到P端口通道。如果从U发送到P,P到U通道停止意味着抛出异常?原因何在? 当做 吉坦贾利 以上来自于百度翻译 以下为原文 Hello, I am using slavefifo application,i modified control centre for this. i am streaming contineous data from p port to u port in the endpoint 0x81,while streaming ,i am sending data in the control centre endpoint 0x01 that is u port to p port channel.if i send this from u to p,p to u channel stops means throwing exception?what whould be the reason? regards geethanjali |
不cdvdhgdh 发表于 2018-10-3 19:37 你好, 请检查从FPGA到FX3的A[1:0]行。您可以创建两个用于读写的DMA通道,但FPGA和FX3之间的通信是半双工的。如果你想把模式从读变成写,反之亦然,你就必须切换地址线A[1:0]。 感谢和问候 阿比纳夫 以上来自于百度翻译 以下为原文 Hi, Please check for the A[1:0] lines from FPGA to FX3. You can create two DMA channels for reading and writing but communication between FPGA and FX3 is half duplex. You have to switch Address lines A[1:0], if you want to switch the mode from reading to writing or vice - versa. Thanks & regards Abhinav |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
511浏览 2评论
470浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-3 13:06 , Processed in 0.762791 second(s), Total 51, Slave 45 queries .
