我们正在运行带有Horizon 7.0的NVIDIA M60-0Q vGPU,并且全屏应用程序存在问题。
例如,当我们将PowerPoint置于“幻灯片放映”模式时,我们看到的只是第一张幻灯片。 当我们翻阅幻灯片并到达终点时,它退出全屏模式并返回桌面。 打印屏幕指示幻灯片正在帧缓冲区中生成,但未发送到远程客户端。 同样,运行像Unigine Heaven这样的3D应用会导致屏幕冻结。 由于该应用程序不会自行终止,因此需要断开会话才能重新获得对桌面的访问权限。 无论我们使用Blast还是PCoIP,都会发生这种情况。 有解决方法吗? 以上来自于谷歌翻译 以下为原文 We are running NVIDIA M60-0Q vGPUs with Horizon 7.0 and having issues with applications that go full screen. For example, when we place PowerPoint in "slide show" mode, all we see is the first slide. As we page through the slide deck and reach the end, it exits full screen mode and the desktop returns. Print screens indicate that the slides are being generated in the frame buffer, but not being sent to the remote client. Similarly, running a 3D app, like Unigine Heaven, results in a frozen screen. Since that application doesn't terminate on its own, a session disconnect is required to regain access to the desktop. This happens whether we use Blast or PCoIP. Is there a workaround |
虽然它更像是一种解决方法,但我使用“nView桌面管理器”找到了解决同样问题的方法。
通过右键单击桌面,选择nView(必须安装),在配置文件下选择“财务”并应用。 这纠正了这个问题。 以上来自于谷歌翻译 以下为原文 Although its more of a work around, I found a solution to this same problem using the "nView Desktop Manager" Found from Right clicking the desktop, choose nView (must be installed) and under profiles choose "Finance" and apply. This corrected the issue. |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3184 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3592 浏览 4 评论
GMT+8, 2025-3-7 05:02 , Processed in 0.821179 second(s), Total 75, Slave 59 queries .
