到目前为止,我们有一些适用于每个ENA分析仪的软件,但是我们刚刚接收了E5080A,并且许多命令似乎已经改变,例如:在所有其他ENA上,将扫描时间设置为
5秒,你会在E5080A上使用它:SENS:SWE:DEL 5,你会使用它:SENS:SWE:tiME 5这个新的命令集是否会成为ENA分析仪向前发展的新标准,或者这只是 E5080A的一次性使用? 以上来自于谷歌翻译 以下为原文 We have some software that has worked with every ENA analyzer up till now, however we just took delivery of a E5080A, and many of the commands seem to have changed, one example is this: On all other ENA's, to set the sweep time to 5 seconds, you would use this: SENS:SWE:DEL 5 on the E5080A, you would use this: SENS:SWE:TIME 5 Is this new command set going to be the new standard for ENA analyzers moving forward, or is this just a one-off for the E5080A? |
E5080A基于是德科技新推出的通用VNA平台,该平台将用于Keysight新推出的VNA型号(PNA,ENA,PXI VNA,......)。
这些新的VNA产品的SCPI命令,包括E5080A,与现有的PNA的SCPI命令基本相同或相似。 Yasuhiro Mori / Keysight Technologies 以上来自于谷歌翻译 以下为原文 The E5080A is built on Keysight's new common VNA platform, which will be commonly used for Keysight's new VNA models coming from now (PNAs, ENAs, PXI VNAs, ...). And the SCPI commands of these new VNA products, including the E5080A, are basically same as or similar to the existing PNA's SCPI commands. Yasuhiro Mori / Keysight Technologies |
huazhe 发表于 2018-10-2 13:16 感谢您的答复。 这是否意味着任何新的6和7系列ENA型号也会使用这个标准命令集? 以上来自于谷歌翻译 以下为原文 Thank you for the reply. Does this mean that also any new 6 and 7 series ENA models will also use this standard command set too? |
1030 浏览 0 评论
2276 浏览 1 评论
2063 浏览 1 评论
1933 浏览 5 评论
2806 浏览 3 评论
797浏览 1评论
583浏览 0评论
676浏览 0评论
2462浏览 0评论
1519浏览 0评论
GMT+8, 2024-9-20 14:35 , Processed in 1.375630 second(s), Total 47, Slave 42 queries .
