嗨,有可能在“OLTD”TCP/IP STACK硬件SSL/TLS中实现。对于软件解决方案,没有更多的资源。谢谢帮助。安迪
以上来自于百度翻译 以下为原文 Hi, It is possible to implementing in 'old' TCP/IP Stack hardware SSL/TLS. For software solution there are no resources more. Thanks for Help. Andy |
3个回答
作为猜测,您需要大量的代码空间和时间来进行加密和解密。我不认为PIC18有它。
以上来自于百度翻译 以下为原文 As a Guess No. You would need alot of code space and time to do the encryption and decryption. I do not think the PIC18 has it. |
如果使用WiC1500 WiFi模块,则内置TLS。TCP/IP协议栈也是如此,所以不需要使用MLA堆栈代码。您确实需要对芯片进行SPI驱动,并在Atmel库代码上运行端口。
以上来自于百度翻译 以下为原文 If you use the WINC1500 WiFi module TLS is built in. So is the TCP/IP stack, so you do not need to use the MLA stack code. You do need to impement the SPI driver for the chip, and port over the Atmel library code. |
谢谢你的回答。我有PIC18F67 J60的应用程序(多年来不能改变它),并且没有更多的资源(工作,但太大)来自MLA 5.xx的SSL解决方案。我想做加密/解密。是否有人通过SPI、AT2C、PIC18或任何其他解决方案来体验ATMEL加密设备?谢谢
以上来自于百度翻译 以下为原文 Thanks for answers. I have application with PIC18F67J60 (since years and can not change it) and have no more resources for (working but far too large) SSL solution from MLA 5.xx. I want to make encryption/decryption outside. Do have anybody experience with e.g. Atmel Encryption devices via SPI, I2C with PIC18 or any another solution? Thanks |
5282 浏览 9 评论
2054 浏览 8 评论
1967 浏览 10 评论
3228 浏览 3 评论
2275 浏览 5 评论
820浏览 1评论
708浏览 1评论
652浏览 1评论
709浏览 0评论
605浏览 0评论
GMT+8, 2025-1-11 12:27 , Processed in 1.145992 second(s), Total 48, Slave 43 queries .
