您好,我用DMA接口两个DSPIC33 EP的过SPI。传输工作很好,我有一个关于我处理CS的方式的问题。我这样做了。-在启用DMA i之前,设置一个定时器。在DMA传输中完成中断,启用定时器,一旦定时器中断拉CS高,禁用timeReTe看起来像是浪费资源。有没有更好的处理CS线的方法?如果我在DMA传输完全中断中拉CS高,定时的时间有时太快,并且接收端不能得到整个传输。因此,我需要延迟切换CS,因此计时器。如何处理DMA的CS?
以上来自于百度翻译 以下为原文 Hello, I am interfacing two dspic33ep's over SPI with DMA. The transfer works fine, I have a question about the way I handle the CS. The way I do it is; - Setup up a timer - before enabling the DMA I pull the CS low. - in DMA transfer complete interrupt, enable timer, - once timer interrupts pull CS high, disable timer This seems like a waste of resources. Is there a better way of handling the CS line ? If I pull the CS high in DMA transfer complete interrupt, timing wise it is sometimes too soon, and the receiving side doesn't get the whole transfer. So it seems I need to delay toggling the CS, thus the timer. How do you handle CS with DMA ? |
在“DMA完成”中断服务中启用SPI中断。当最后一次传输完成时,您将得到中断。
以上来自于百度翻译 以下为原文 Enable the SPI interrupt in the "DMA complete" interrupt service. You will then get an interrupt when that last transfer completes. |
你尝试过框架SPI模式吗?在这种模式下,您不必担心CS信号,尽管它的工作方式与普通SPI模式稍有不同。
以上来自于百度翻译 以下为原文 Have you tried Framed SPI mode? In this mode, you don't have to worry about the CS signal, although it works a little different to the normal SPI mode. |
5383 浏览 9 评论
2107 浏览 8 评论
2009 浏览 10 评论
3285 浏览 3 评论
2319 浏览 5 评论
889浏览 1评论
779浏览 1评论
714浏览 1评论
773浏览 0评论
665浏览 0评论
GMT+8, 2025-3-10 18:55 , Processed in 1.458004 second(s), Total 78, Slave 62 queries .
