我需要一个能够区分20mm到23mm距离且无误差的传感器。
即精度和稳定性必须很高(仅在1mm以内) 我应该使用VL6180或VL53L或其他传感器? 以上来自于谷歌翻译 以下为原文 I need a sensor that is able to differentiate between distance 20mm and 23mm with no error. i.e. the accuracy and stability must be high (within 1mm only) which sensor should I use VL6180 or VL53L or something else? |
哎哟这很难。所有ST飞行时间传感器返回约+/- 3%。很明显,这超出了你的极限。但是购买VL53L1X评估套件。采用非常长的积分时间 - (时间预算)。如果你可以调整你的目标(并且它不是一些随机的东西,你应该能够接近。我有一个客户用VL53L0X做一个医疗设备,他在2mm以内。所以如果你有一致的距离,并且一致目标,你应该能够非常接近。
通常,ToF传感器可以是低功率,高精度或长距离。但你只能得到其中一个。 在你的情况下,你没有提到动力,需要高精度并且不担心距离。 因此请使用VL53L1X并使用较长的时序预算。 以上来自于谷歌翻译 以下为原文 Ouch that's a hard one. All the ST Time of Flight sensors return about +/- 3%. So clearly that is outside your limit. But buy the VL53L1X evaluation kit. Go with a very long integration time - (timing budget). If you can condition your target (and it's not some random thing, you should be able to get close. I have a customer doing a medical device with the VL53L0X and he gets within 2mm. So if you have a consistent distance, and a consistent target, you should be able to come very close. As a rule the ToF sensors can be low power, high accuracy or long distance. But you only get one of those. In your case, you didn't mention power, need high accuracy and aren't worried about distance. So go with the VL53L1X and use a long timing budget. |
2877 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3710 浏览 6 评论
6124 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 08:10 , Processed in 1.110153 second(s), Total 77, Slave 61 queries .
