我们有一个使用Grid K2机器的系统。
我试图在一个vm的侧面设置cuda。 当我使用驱动程序下载页面时,它指向NVIDIA-Linux-x86_64-367.57版本的驱动程序似乎工作(它们安装了预期的模块,nvidia-smi没有错误) 然而,当我去安装当前下载的cuda(cuda_9.1.85_387.26_linux)时,它安装了一个更新版本的驱动程序(387.26),它似乎不支持我们的Grid K2板(模块停止加载和nvidia- smi错误)虽然我可以找到旧版本的cuda,例如9.0或8.0,但它们似乎都需要相同的387.26驱动程序,而不是367.57。 你能指点我到基于Grid K2系统下载cuda软件包的正确位置吗? 以上来自于谷歌翻译 以下为原文 We have a system using Grid K2 machines. I am trying to setup cuda in side a vm. When I use the driver download page it points me to the NVIDIA-Linux-x86_64-367.57 version of the drivers which seem to work (they install the expected modules and nvidia-smi doesn't error) However when I go to install the current download of cuda (cuda_9.1.85_387.26_linux) it installs a newer version of the driver (387.26) which doesn't seem to support the Grid K2 board we have (module stops loading and nvidia-smi errors) While I can find old versions of cuda e.g 9.0 or 8.0 they all seem to require the same 387.26 driver rather than the 367.57 which works. Could you point me to the correct place to download the cuda package for a Grid K2 based system? |
https://gridforums.nvidia.com/default/topic/8698/nvidia-virtual-gpu-drivers/grid-k1-amp-cuda/
以上来自于谷歌翻译 以下为原文 https://gridforums.nvidia.com/default/topic/8698/nvidia-virtual-gpu-drivers/grid-k1-amp-cuda/ |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3176 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3587 浏览 4 评论
GMT+8, 2025-2-24 04:32 , Processed in 0.493463 second(s), Total 45, Slave 39 queries .
