嗨,我想知道电路板走线的延迟,很难测量横截面来计算C或L.所以我可以使用两个微探针(已知长度)并在迹线上放置微探针和
另一个例如,如果我想测量迹线的电容,它会去哪里? 我没有时域,所以是否可以在VNA中获得没有时域的长度和速度因子? 谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I want to know the delay of a circuit board trace it would be very hard to measure the cross section to calculate the C or L. So can I use two microprobes (of known lengths) and put on microprobe pin on the trace and the other for example if I want to measure the Capacitance of a trace where would it go?. I have no time domain, so Is it possible to get the length and velocity factor without time domain in a VNA? thanks. |
3个回答
您好,这是一种测量回波损耗组延迟并采取一半的简单威廉希尔官方网站
在PNA和ENA中有端口扩展选项,可以帮助您测量线路,但在线路末端使用开放和短路,Mike Virostko 以上来自于谷歌翻译 以下为原文 Hello, A simple technique to to measure the return loss group delay and take half of it. Within the PNA and ENA are Port Extension options which can help you measure the line but using open and shorts at the end of the line, Mike Virostko |
康达LOODER 发表于 2018-10-1 11:19 非常感谢Mike,但我被告知端口扩展仅在50欧姆阻抗线上工作良好,所以如何在没有良好校准的情况下知道什么阻抗是迹线? 以上来自于谷歌翻译 以下为原文 Thanks a lot Mike but I was told the port extensions works good only in 50Ohm impedances lines so how can I know what impedance is the trace without a good calibration? |
不是我的知识。 不匹配会影响幅度,但不影响相位。 以上来自于谷歌翻译 以下为原文 Not to my knowledge. The mismatch will affect the magnitude, but not the phase. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1423浏览 1评论
827浏览 0评论
1193浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-24 09:04 , Processed in 1.340438 second(s), Total 78, Slave 62 queries .
