扫一扫,分享给好友
static void DAC_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; DAC_InitTypeDef DAC_InitStructure; /* 使能GPIOA时钟 */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); /* 使能DAC时钟 */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE); /* DAC的GPIO配置,模拟输入 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5 ; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_Init(GPIOA, &GPIO_InitStructure); /* 配置DAC 通道1 */ DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software; //使用软件触发 DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None; //不使用波形发生器 DAC_InitStructure.DAC_Buffer_Switch = DAC_BufferSwitch_Disable; //不使用DAC输出缓冲 DAC_Init(DAC1,DAC_Channel_1,&DAC_InitStructure); /* 配置DAC 通道2 */ DAC_InitStructure.DAC_Trigger = DAC_Trigger_Software; DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_Triangle; DAC_InitStructure.DAC_Buffer_Switch = DAC_BufferSwitch_Disable; DAC_Init(DAC1, DAC_Channel_2,&DAC_InitStructure); /* 使能通道1 由PA4输出 */ DAC_Cmd(DAC1,DAC_Channel_1, ENABLE); /* 使能通道2 由PA5输出 */ DAC_Cmd(DAC1,DAC_Channel_2, ENABLE); } void DAC_test(void) { DAC_Config(); //调用DAC初始化函数 DAC_DualSoftwareTriggerCmd(DAC1,ENABLE); //同时启用两个DAC通道触发器 DAC_SetChannel2Data(DAC1,DAC_Align_12b_R,0xfff); //设置通道1输出电压值大约为3.3V DAC_SoftwareTriggerCmd(DAC1,DAC_Channel_1,ENABLE);//使能DAC通道1 DAC_SetChannel2Data(DAC1,DAC_Align_12b_R,0x555);//设置通道1输出电压值大约为1.1V DAC_SoftwareTriggerCmd(DAC1,DAC_Channel_2,ENABLE);//使能DAC通道2 } int main(void) { DAC_test(); while (1) { } }//通道1输出最大的时候也只是0.6V,而且根本不按程序的值输出。 |
6个回答
恭喜楼主已经解决了
我太粗心了,DAC_SetChannel2Data(DAC1,DAC_Align_12b_R,0xfff); 把这句改成:DAC_SetChannel1Data(DAC1,DAC_Align_12b_R,0xfff); 就好了
不懂帮顶
三思而后行啊
不懂帮顶
多细心点就好了
2060 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1216 浏览 0 评论
2815 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
2584 浏览 3 评论
5265 浏览 0 评论
GMT+8, 2025-1-13 01:52 , Processed in 0.648257 second(s), Total 50, Slave 45 queries .
