嗨,CX3能支持4K RAW10@ 30FPS分辨率吗?还是4K RAW8@ 30FPS?
如果CYU3PMIPICSIREST()在CYU3PMIPICSIIIT()之前初始化,它将报告错误CYU3PMIPICSICALSER Err=0x44,然后在CYU3PMIPICSIIIT()之后初始化成功。 但是现在CX3DMA不能接收MIPI数据,MIPI端可以用数据来测量,为什么你不能接收数据? 谢谢! 以上来自于百度翻译 以下为原文 Hi,Can CX3 support 4K raw10 @30fps resolution? or 4K raw8 @30fps ? If CyU3PMipicsiReset() is initialized before CyU3PMipicsiInit (), it will report the error CyU3PMipicsiReset Err = 0x44, and then the initialization succeeds after CyU3PMipicsiInit (). But now cx3 DMA cannot receive mipi data, and the mipi end can be measured with data,Why can't you receive data? thank ! |
编辑:
1。0x44是当我们重置MIPI而不初始化它时出现的。在API指南中引用5.25.611 CYU3PRESTROSTATUS SWT CUU3PMIPICSIRSET(CYU3PMIPICSIRESETHETREST类型)。 2 CX3可以支持最大2.4 Gbps。 CX3上的MIPI块支持多达四条数据通道 每个车道支持高达1 Gbps。 注意:CYSUB3065支持多达四个车道;CysB3064支持多达两个车道。 三。按照您的要求: 1。4K RAW 10 30fps=(3840 +水平消隐)*(2160 +垂直消隐)* 10×30=2.488 Gbps>2.4 Gbps(假设消隐为零)。理想情况下,应该有消隐周期)-CX3不支持 2。4K RAW 8×30 fps=(3840 +水平消隐)*(2160 +垂直消隐)* 8×30=1.99 Gbps<2.4 Gbps(假设消隐为零)。理想情况下应该有消隐周期-CX3支持 4。在这种情况下,您使用的MIPI配置是什么,帧速率、分辨率、每秒帧数和每像素位数是多少? 以上来自于百度翻译 以下为原文 Edited: 1. 0x44 comes when we reset the MIPI without initializing it. Refer 5.25.6.11 CyU3PReturnStatus_t CyU3PMipicsiReset ( CyU3PMipicsiReset_t resetType ) in API Guide. 2 CX3 can supports at maximum 2.4 Gbps. MIPI block on CX3 supports up to four data lanes Each lane supports up to 1 Gbps Note: CYUSB3065 supports up to four lanes; CYUSB3064 supports up to two lanes 3. As per your requirement: 1. 4K RAW 10 30fps = (3840+Horizontal Blanking) * (2160+ Vertical Blanking) * 10 * 30 = 2.488 Gbps > 2.4 Gbps ( Assume blanking is Zero. Ideally there should be blanking period) - CX3 Does Not Support 2. 4K RAW 8 30 fps = (3840+Horizontal Blanking) * (2160+Vertical Blanking) * 8 * 30 = 1.99 Gbps < 2.4 Gbps (Assume blanking is Zero. Ideally there should be blanking period) - CX3 Supports 4. What is the MIPI configuration that you are using in this case, what is the frame rate, resolution, frames per second and bits per pixel? |
yahan52 发表于 2018-10-1 12:24 亲爱的Srdr, 虽然有效载荷3840×2160×30×8小于2.4GbPs,但是我不能成功配置CX3。 我知道tc358746 CX3嵌入东芝芯片,我得到一个XLS工具从东芝用它配置3840*2160 * 30fps×8bit(raw8)。 看来最大FPS是11左右,所以你能分享如何配置4k raw8图像传感器,如索尼IMX135? 戴维 以上来自于百度翻译 以下为原文 Dear Srdr, Although the payload 3840*2160*30 *8 is less than 2.4Gbps, but I cannot configure CX3 successfully. I know CX3 embed a tc358746 from Toshiba in chip, I get an XLS tool from Toshiba and use it configure 3840*2160*30fps*8bit(raw8). It seems the max fps is about 11, so can you share how to configure 4K raw8 image sensor ,eg, sony IMX135? David |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 12:37 , Processed in 0.398571 second(s), Total 43, Slave 38 queries .
