大家好,
我使用结构描述编写了我的设计,我想使用floorplanner / FPGA编辑器来设置/路由设计。 当我在floorplanner / FPGA Editor中打开设计时,如何识别每个组件 FPGA怪胎 以上来自于谷歌翻译 以下为原文 Hi all, I coded my design using structural description and i want to place/route the design using floorplanner/FPGA editor. When i open the design in floorplanner/FPGA Editor, how do i identify each component FPGA freak |
嗨,
如果您有一个实现的设计,一旦打开FPGA编辑器,您将能够看到一个列表窗口。 如快照中所示,您可以看到组件。 谢谢, HS -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hi, https://bbs.elecfans.com/file:///C:/Temp/moz-screenshot.jpghttps://bbs.elecfans.com/file:///C:/Temp/moz-screenshot-1.jpg If you have a implemented design, once you open the FPGA editor you will be able to see a List window. As seen in the snapshot, you can see the components. Thanks, HS ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
2468 浏览 7 评论
2855 浏览 4 评论
2317 浏览 9 评论
3400 浏览 0 评论
2498 浏览 15 评论
2110浏览 1评论
640浏览 1评论
498浏览 1评论
2048浏览 0评论
778浏览 0评论
GMT+8, 2025-1-31 19:45 , Processed in 0.992203 second(s), Total 42, Slave 37 queries .
