大家好,
我继承了一个基础设施,我需要一些帮助,了解如何正确配置Grid K2卡。 以下是设置的概要: 虚拟机管理程序: HP DL380 Gen9 双E5-2630 v3 8核CPU 64GB RAM 2x146GB 15K SAS驱动器 4x300GB 15K SAS驱动器 NVIDIA GRID K2 RAF PCIe GPU套件(图形选项)(在设备管理器中显示为2个物理GPU) - 运行Windows 2012 R2 Standard - 是Hyper-V主机 - 安装了Grid K2驱动程序版本21.21.13.6949 - 在RemoteFX使用的Hyper-V设置中启用了两个物理GPU 访客虚拟机: Windows 7企业版 RemoteFX的配置已到位 VM显示RemoteFX图形设备 - WDDM是显示适配器 这些VM中有4个,所有VM都配置相同且在此主机上 因此,从它看起来,VM都设置并连接到GRID K2卡。 问题是GPU的马力和刷新是可怕的! 如果我远程调用从Hyper-V中的每个VM调整的RemoteFX并重新启动,则本机RDP图形虚拟GPU和驱动程序要快得多(尽管对于任何快速运动或视频来说都很糟糕,但它们仍然比RemoteFX快得多)。 是否有一些我缺少的东西让主机和/或VM充分利用K2s的全功率? 谢谢, 贾森 以上来自于谷歌翻译 以下为原文 Hello All, I have inherited an infrastructure that I need some help understanding how to properly configure a Grid K2 card on. Here is the synopsis of the setup: Hypervisor: HP DL380 Gen9 Dual E5-2630 v3 8core CPU 64GB RAM 2x146GB 15K SAS Drives 4x300GB 15K SAS Drives NVIDIA GRID K2 RAF PCIe GPU Kit (Graphics option) (Shows in device manger as 2 Physical GPUs) - Runs Windows 2012 R2 Standard - Is the Hyper-V host - Grid K2 Driver version 21.21.13.6949 installed - Both physical GPUs are enabled in Hyper-V Settings for RemoteFX usage Guest VMs: Windows 7 Enterprise Edition Configurations for RemoteFX are in place VMs show that RemoteFX Graphics Device - WDDM is the display adapter There are 4 of these VMs, all configured identically and on this host So, from what it looks like, the VMs are all setup and connecting to the GRID K2 card. The problem is that GPU horsepower and refresh are horrible! If I remote the RemoteFX adapted from each of the VMs in Hyper-V and reboot, the native RDP graphics virtual GPU and driver are significantly faster (although horrible for any fast motion or video, they're still much faster than the RemoteFX). Is there something that I am missing to get the host and/or VMs to take advantage of the K2s full horsepower? Thanks, Jason |
3个回答
嗨,杰森
查看组策略,您需要在Windows VM中配置其中一个用于使用GPU的设置: “Windows组件/远程桌面服务/远程桌面会话主机/远程会话环境 - 使用硬件默认图形适配器进行所有远程桌面服务会话” 这个帖子可以帮助你...忽略不同的GPU,但这里有一些设置可以为你提供一些调查选项(也可以通过GPO): https://gridforums.nvidia.com/default/topic/1175/m10-for-video-on-vmware-running-rds-2016-/?offset=14#4521 问候 本 以上来自于谷歌翻译 以下为原文 Hi Jason Have a look in Group Policy, one of the settings you need to have configured in your Windows VM for it to use the GPU is: "Windows Components/Remote Desktop Services/Remote Desktop Session Host/Remote Session Environmentshow - Use the hardware default graphics adapter for all Remote Desktop Services sessions" This thread may help you ... Ignore the different GPU, but there are some settings here that will give you some options to investigate (also through a GPO): https://gridforums.nvidia.com/default/topic/1175/m10-for-video-on-vmware-running-rds-2016-/?offset=14#4521 Regards Ben |
嗨本
感谢您的答复。 在调查之后,已在安装了该卡的Windows Server 2012 Hyper-V Hypervisor计算机中启用了该GPO。 Windows 7企业VM中不存在此GPO设置。 如果有意义的话,看起来虚拟机似乎都在卡上打了1个核心。 我知道虚拟机正在看K2卡,因为RemoteFX已启用并在我进入虚拟机时使用。 我只是不知道卡的资源被用得多少。 谢谢, 贾森 以上来自于谷歌翻译 以下为原文 Hi Ben Thank you for the response. After investigating, that GPO is already enabled in the Windows Server 2012 Hyper-V Hypervisor machine where the card is installed. This GPO setting doesn't exist in the Windows 7 Enterprise VMs. It almost seems like the VMs are all hitting 1 core on the card, if that makes sense. I know that the VMs are seeing the K2 card because RemoteFX is enabled and being utilized when I RDP into the VMs. I just dont see where the card's resources are being utilized much. Thanks, Jason |
对不起,那是我的错。
我误读了您的原始帖子,并认为您正在进行RDS部署,这就是我链接到该帖子的原因,这显然与此部署无关。 快速阅读这里,看看有什么可以帮助: https://social.technet.microsoft.com/wiki/contents/articles/16652.remotefx-vgpu-setup-and-configuration-guide-for-windows-server-2012.aspx 问候 本 以上来自于谷歌翻译 以下为原文 Sorry, that's my mistake. I misread your original post and thought you were doing an RDS deployment which is why I linked to that post, which obviously isn't relevant in this deployment. Have a quick read through here and see if there's anything that can help: https://social.technet.microsoft.com/wiki/contents/articles/16652.remotefx-vgpu-setup-and-configuration-guide-for-windows-server-2012.aspx Regards Ben |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3129 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3539 浏览 4 评论
GMT+8, 2024-12-26 00:29 , Processed in 0.445960 second(s), Total 45, Slave 40 queries .
