我需要测量一个信号,以确定它在很长一段时间内切换的频率。
我的MSO7104B示波器是否是正确的工具? 我想我的最终答案是“当产品处于睡眠模式时信号高(或切换或激活)10%的时间”。 如果你能想到另一种能更好的工具,我可以使用各种设备。 以上来自于谷歌翻译 以下为原文 I need to measure a signal to figure out how often it is toggling over a long period of time. Is my MSO7104B scope the right tool? I would like my final answer to be something like "the signal is high (or toggling or active) 10% of the time when the product is in sleep mode". I have access to all sorts of equipment if you can think of another tool that would work better. |
什么是“很长一段时间”?
几分钟,几分钟,几天? 范围通常更适合更快的事件。 我可能会使用逻辑分析仪,处于任一状态模式(使用切换信号作为时钟)或过渡时序模式。 您不会立即获得实际数字,但可以将时间值导出到Excel,并获得确切的数字。 人 以上来自于谷歌翻译 以下为原文 What is "a long period of time"? Seconds, minutes, days? Scopes are usually better for faster events. I would probably use a Logic Analyzer, in either State mode (use the toggling signal for the clock), or Transitional Timing mode. You won't get the actual number right off, but you could export the time values to Excel, and get an exact number. Al |
1607 浏览 0 评论
2560 浏览 1 评论
2433 浏览 1 评论
2271 浏览 5 评论
3207 浏览 3 评论
1019浏览 0评论
1607浏览 0评论
GMT+8, 2025-7-13 14:25 , Processed in 1.298519 second(s), Total 45, Slave 39 queries .
