我用tiM1的ch1和ch1N,ch2和ch2N产生两对互补的PWM波,ch3和ch4产生相位相差180度的PWM,但现在问题是产生的互补的PWM波没有问题,但是相位相差180度的PWM波只有一路有波形,另外一路没有输出(始终是低),相位相差180度的ch3和ch4的初始化配置如下:
GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; /* GPIOA clocks enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); /* TIM1 clock enable */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_11; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; GPIO_Init(GPIOA,&GPIO_InitStructure); /* Connect TIM pins to AF6 */ GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_6); GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_6); /* Time Base configuration */ TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1; TIM_TimeBaseStructure.TIM_Period = 600; TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable; TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low; TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset; TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset; TIM_OCInitStructure.TIM_Pulse = 200; TIM_OC3Init(TIM1,&TIM_OCInitStructure); TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; TIM_OCInitStructure.TIM_Pulse = 400; TIM_OC4Init(TIM1,&TIM_OCInitStructure); TIM_CtrlPWMOutputs(TIM1, ENABLE); TIM_Cmd(TIM1,ENABLE); 求高手帮忙指点,谢谢。 |
6个回答
只需要改OCMode一个参数就好,Pulse不用改吧,不然就不是差180度了
PWM模式加占空比调整
谢谢楼上两位的回复支持,问题已经解决,原因:PA11不能配置为GPIO_AF_6,需配GPIO_AF_11才可以。
GPIO_AF_6和GPIO_AF_11是什么作用呀?对应管脚吗?
是因为你搞错引脚了吗? 每个引脚都可以被配置为AF模式吧 |
从提供的库文件上看对引脚用为tim1输出pwm 可以是AF_6也可以是AF_11的
1785 浏览 1 评论
1758 浏览 1 评论
求助大佬我使用STM32F030F4P6 的PA3引脚输出PWM波形
1620 浏览 0 评论
1815 浏览 1 评论
STM32H750VB sys为什么无法选择debug模式?
1971 浏览 1 评论
GMT+8, 2025-4-14 21:47 , Processed in 0.782882 second(s), Total 50, Slave 45 queries .
