你好!
我正在设计一个MIL-STD控制器。 该标准意味着使用直接或变压器耦合连接到总线。 我是否可以使用内部FPGA的资源来完成此连接方法,ori是否必须使用其他外部设备? 先谢谢你! 以上来自于谷歌翻译 以下为原文 Hello!I'm designing a MIL-STD controller. This standard implies connection to the bus using direct or transformer coupling. Can i accomplish this connection method using only internal FPGA's resources, or i have to use additional external devices?Thank you in advance! |
叶夫根尼,
您没有指定您正在使用的FPGA系列,但在这种情况下它并不重要...... 我不知道有哪些FPGA系列能够处理1553总线上可以看到的~9V。 当然可以在FPGA中设计MIL-STD-1553控制器。 我知道几个,包括Condor(现在的GE Fanuc)和Digital Design Corporation。 您肯定需要使用外部1553收发器和可选的变压器。 您可能会发现这是一些物理层问题的有用资源: http://www.ddc-web.com/FAQ/Databus/Standards.aspx 请注意,大多数1553资源不直接寻址FPGA,因为原始规范早于FPGA。 请注意,Virtex和Spartan-II是5V容限的Xilinx FPGA系列中的最后一个。 干杯, BT 以上来自于谷歌翻译 以下为原文 Evgeniy, You don't specify which FPGA family you are using, but in this case it doesn't really matter...I don't know of any FPGA families capable of handling the ~9V you can see on the 1553 bus.It certainly is possible to design a MIL-STD-1553 controller in an FPGA. I know of several, including Condor (now GE Fanuc) and Digital Design Corporation.You will definitely need to use an external 1553 transceiver and optional transformer.You may find this a useful resource on some of the physical layer questions:http://www.ddc-web.com/FAQ/Databus/Standards.aspxNote that most 1553 resources don't directly address FPGAs since the original specification predates FPGAs. Note that Virtex and Spartan-II are the last of the Xilinx FPGA families that were 5V tolerant. Cheers,bt |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2447浏览 1评论
659浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 06:56 , Processed in 1.376550 second(s), Total 77, Slave 61 queries .
