您好,我必须打开旧的原理图文件(2002年,Xilinx Foundation F3.1i),但我不能使用9.2i版本。我收到此消息:在fileThanksSimone中未检测到设计单元
以上来自于谷歌翻译 以下为原文 Hello, I have to open old schematics files (year 2002, Xilinx Foundation F3.1i ) but I can't with the 9.2i version. I receive this message: No design units detected in file Thanks Simone |
那个时代的基础原理图是基于Aldec的。
Xilinx和 Aldec不再拥有通用工具。 可以打开这些 在基础版本中,如果您有一个旧版本,最高可达4.1i,但是 这些旧版本中基于Aldec的工具不再可用 赛灵思。 也可以在Aldec的新工具中打开它们, 可直接从Aldec获得。 鉴于你有这些旧的 文件,我建议你看看你是否可以挖掘基础工具 用于生成它们的。 HTH, 的Gabor - Gabor 以上来自于谷歌翻译 以下为原文 Foundation schematics from that era were Aldec-based. Xilinx andAldec no longer have common tools. It is possible to open thesein Foundation versions up to 4.1i if you have an old copy, however theAldec-based tools in these older versions are no longer available fromXilinx. It is also possible to open them in Aldec's newer tools,available directly from Aldec. Given that you have these oldfiles, I would suggest seeing if you can dig up the Foundation toolsthat were used to generate them. HTH, Gabor -- Gabor |
2436 浏览 7 评论
2833 浏览 4 评论
2305 浏览 9 评论
3383 浏览 0 评论
2479 浏览 15 评论
1569浏览 1评论
606浏览 1评论
471浏览 1评论
2022浏览 0评论
745浏览 0评论
GMT+8, 2025-1-4 18:32 , Processed in 1.038046 second(s), Total 43, Slave 38 queries .
