Grin K2和Grid K520有什么威廉希尔官方网站
差异?
我需要在Citrix XenServer虚拟机管理程序上为基于Autodesk的GPU应用程序选择一个 以上来自于谷歌翻译 以下为原文 What is the technical difference between Grin K2 and Grid K520? I need to choose one for Autodesk based GPU applications on a Citrix XenServer hypervisor |
3个回答
K520将不再作为vGPU支持,只支持K2。
K340和K520更适合游戏设计。 以上来自于谷歌翻译 以下为原文 The K520 won't be supported as a vGPU for one, just the K2. The K340 and K520 are designed more for gaming. |
可能不感兴趣,因为K2是适当的GPU,但网页http://www.nvidia.com/object/cloud-get-started.html显示哪些中间件,IaaS,OEM硬件合作伙伴和云游戏引擎合作伙伴支持
K340和K520。 Erik Bohnhorst | 解决方案架构师 - GRID NVIDIA公司 以上来自于谷歌翻译 以下为原文 Probably not of interest for you since the K2 is the appropriate GPU but the webpage http://www.nvidia.com/object/cloud-get-started.html shows which middleware, IaaS, OEM hardware partners and cloud game engine partners support the K340 and K520. Erik Bohnhorst | Solution Architect – GRID NVIDIA Corporation |
在这里,您可以获得有关K1和K2的更多信息:http://www.nvidia.com/content/cloud-computing/pdf/nvidia-grid-datasheet-k1-k2.pdf和http://www.nvidia.com
/object/grid-boards.html K340和K520:http://www.nvidia.com/object/cloud-gaming-gpu-boards.html 以上来自于谷歌翻译 以下为原文 Here you can get more info about K1 and K2: http://www.nvidia.com/content/cloud-computing/pdf/nvidia-grid-datasheet-k1-k2.pdf and http://www.nvidia.com/object/grid-boards.html K340 and K520: http://www.nvidia.com/object/cloud-gaming-gpu-boards.html |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3130 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3542 浏览 4 评论
GMT+8, 2024-12-26 11:51 , Processed in 0.586058 second(s), Total 71, Slave 65 queries .
