我在RHEL 4更新4 - 64位操作系统中安装了xilinx ISE 10.1
在运行ISE时,我得到了跟随共享库的错误 gcc版本isntalle s 3.4.6 请帮助 server / project / puneetbhatia> xps xps:/softs/ius/tools.lnx86/lib/libgcc_s.so.1:未找到版本“GCC_3.3” (/softs/xilinxedk/EDK/lib/lin/libstdc++.so.6要求) server / project / puneetbhatia> xpsgui xpsgui:加载共享库时出错:libGui_Gfq.so:无法打开 共享对象文件:没有这样的文件或目录 server / project / puneetbhatia> xst xst:/softs/ius/tools.lnx86/lib/libgcc_s.so.1:未找到版本“GCC_3.3” (/softs/xilinxedk/EDK/lib/lin/libstdc++.so.6要求) server / project / puneetbhatia> xst -gui xst:/softs/ius/tools.lnx86/lib/libgcc_s.so.1:未找到版本“GCC_3.3” (/softs/xilinxedk/EDK/lib/lin/libstdc++.so.6要求) server / project / puneetbhatia> 以上来自于谷歌翻译 以下为原文 I had installed xilinx ISE 10.1 in RHEL 4 update 4 - 64 bit os while running ISE , ia m getting followoing shared library error gcc version isntalle s 3.4.6 pls help server/project/puneetbhatia > xps xps: /softs/ius/tools.lnx86/lib/libgcc_s.so.1: version `GCC_3.3' not found (required by /softs/xilinxedk/EDK/lib/lin/libstdc++.so.6) server/project/puneetbhatia > xpsgui xpsgui: error while loading shared libraries: libGui_Gfq.so: cannot open shared object file: No such file or directory server/project/puneetbhatia > xst xst: /softs/ius/tools.lnx86/lib/libgcc_s.so.1: version `GCC_3.3' not found (required by /softs/xilinxedk/EDK/lib/lin/libstdc++.so.6) server/project/puneetbhatia > xst -gui xst: /softs/ius/tools.lnx86/lib/libgcc_s.so.1: version `GCC_3.3' not found (required by /softs/xilinxedk/EDK/lib/lin/libstdc++.so.6) server/project/puneetbhatia > |
你好,
查看Xilinx的答案20154(http://www.xilinx.com/support/answers/20154.htm),看看这是否有帮助。 如果您在遵循此AR后仍遇到问题,请通过www.xilinx.com/support提交WebCase。 我们很乐意为您提供进一步的帮助。 -edv 埃迪 以上来自于谷歌翻译 以下为原文 Hello, Check Xilinx Answer 20154 (http://www.xilinx.com/support/answers/20154.htm), see if this helps. If you are still encountering issues after following this AR, please file a WebCase via www.xilinx.com/support. We'd be glad to help you further. -edv Eddie |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2447浏览 1评论
659浏览 1评论
521浏览 1评论
2075浏览 0评论
801浏览 0评论
GMT+8, 2025-2-24 08:10 , Processed in 1.042834 second(s), Total 44, Slave 39 queries .
