嗨,
我是一名德国学生,我正在从事一个私人项目。它是一种无人机(UnmannedAirVehicle),它通过压力控制它的高度。为此,我想使用LPS331AP,但原始数据输出以大约0.05 Hz的频率进行振荡。通常情况下,我会使用带阻滤波器来减少/减少这种噪音,但如果无人机向上或向下移动,频率可能会/通常是相同的,所以这不适合。 在应用说明“硬件和软件指南”中,它在第16页上说明: ''对于室内导航,当需要子仪表检测时,可以使用特殊的递归滤波器 使用。根据传感器特性和应用要求调整S / W滤波器 通常是一个很好的举动。传感器融合是使用所有可用的最先进的过滤器 信息并使用它们来减少定位噪音。 “” 但我找不到有关这个''递归过滤器'的更多信息。如果过滤器应该是什么样的?我已经在使用传感器融合 - >我将加速度计双重整合以获得高度,并使用互补滤波器将其与LPS331AP读数相结合。但LPS331AP的噪声频率太低而无法确定。 我不需要知道绝对的压力。 感谢阅读和阅读对不起,我的英语不好 #filter#lps331ap #noise 以上来自于谷歌翻译 以下为原文 Hi, i'm a german student and i'm working on a private project. It's a UAV (UnmannedAirVehicle), which controls it's altitude by pressure. For this, i want to use a LPS331AP, but the raw-data output oscilates with a frequency of about 0.05 Hz. Normally, i would use a bandstop filter to reduce / minimize this noise, but if the UAV moves up or down, the frequency can be / will be often the same, so this doesn't fit. In the application note ''Hardware and software guidlines'' it says on page 16: '' For indoor navigation when sub meter detection is required, a special recursive filter could be used. Tailoring the S/W filter for the sensor characteristic and the application requirement is usually a good move. Sensor fusion is the most advanced filtering which uses all available information and uses them to reduce the positioning noise. '' But i can't find any more information about this ''recursive filter''. What sort if filter should this be? I'm allready using sensor fusion -> i double integrate a accelerometer to get the height out of it and use a complementary filter to combine this with the LPS331AP readings. But the noise frequency of the LPS331AP is too low to determine it. I don't need to know the absolute pressure. Thanks for reading & sorry for my bad english #filter #lps331ap #noise |
你好,
感谢您发布您的问题,我可以在您的无人机的这方面为您提供支持。 我正在与ST的应用工程团队一起检查这些信息,我会告诉您这是什么结果。 如果您有任何其他需要帮助的项目,请随时与我联系。 谢谢, 蒂亚戈REIS 以上来自于谷歌翻译 以下为原文 Hello, Thank you for posting your question, I might be able to support you on this aspect of your UAV. I am checking this information with ST´s application engineering team and I will let you know what is the outcome of that. Please do not hesitate to contact me if there is any other item that you would like to receive assistance. Thank you, Thiago REIS |
你好,
首先,谢谢你的回答,但是你写完之后已经有一段时间了,我想知道是否已经有了你可以告诉我的内容。 我真的在等你的回复,因为项目需要这个传感器(或者可能是另一个,如果这个传感器不适合)。 再见 以上来自于谷歌翻译 以下为原文 Hello, first, thank you for your answer, but it's been a while since you've written it and i would like to know if there is allready something you can tell me. I'm really waiting for your reply, because the project needs this sensor (or maybe another one, if this one doesn't fit). Bye |
2829 浏览 1 评论
3268 浏览 1 评论
1844 浏览 1 评论
3694 浏览 6 评论
6100 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
395浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
487浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
316浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
235浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
339浏览 2评论
GMT+8, 2025-2-3 18:06 , Processed in 0.984168 second(s), Total 46, Slave 41 queries .
