哪些参数会影响SNR?哪种评估SNR最好?
以上来自于谷歌翻译 以下为原文 Which are the parameters that impact on SNR? Which is the best way to evaluate the SNR? |
该参数包括MEMS元件的噪声和ASIC。关于这个总和,MEMS传感器给出了对噪声的主要贡献,可以认为集成电路的贡献可以忽略不计。
根据其定义,SNR是灵敏度和残余噪声之间的比率。因此,给定灵敏度,评估这样的参数基本上测量残余噪声水平。通过测量消声环境中的噪声和对采集进行A加权来实现该目标。由于复制完美静音环境的复杂性,SNR是评估麦克风规格中最关键的参数,因此密封麦克风声音入口(即用胶带)将是有帮助的。 亚历山德罗 naue_b 2014年1月16日,星期四,下午5:17 哪些参数会影响SNR?哪种评估SNR最好? 以上来自于谷歌翻译 以下为原文 This parameter includes both the noise of the MEMS element and the ASIC. Concerning this sum, the main contribution to noise is given by the MEMS sensor, the integrated circuit contribution can be considered negligible. As per its definition, the SNR is the ratio between the sensitivity and the residual noise. Hence, given the sensitivity, such parameter is evaluated measuring basically the residual noise level. The goal is achieved by measuring the noise in an anechoic environment and A-weighting the acquisition. The SNR is the most critical parameter to evaluate among the microphone specifications due to the complexity in reproducing a perfect silent environment, hence it would be helpful to seal the microphone sound inlet (i.e with a tape). Alessandro naue_b Thursday, January 16, 2014 5:17 PM Which are the parameters that impact on SNR? Which is the best way to evaluate the SNR? |
2807 浏览 1 评论
3259 浏览 1 评论
1833 浏览 1 评论
3684 浏览 6 评论
6083 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
386浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
477浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
306浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
226浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
329浏览 2评论
GMT+8, 2025-1-27 21:59 , Processed in 0.981077 second(s), Total 77, Slave 61 queries .
