我现在要用STM32驱动一个adc(ad5310),要把cs拉低,clk发送时钟,data发生数据,数据在clk的上升沿取样(原本是下降沿,现在在adc的clk前加了一个反相器),一共要发送16位数据,现在用I/O来模拟不行,用spi模块也不行,为什么?下面是我写的驱动程序,有人能看出问题出在哪里吗?
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE,ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_7; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //spi_clk spi_mosi GPIO_Init(GPIOA,&GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //spi_cs GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOE, &GPIO_InitStructure); SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //SPI_NSS_Hard SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(SPI1,&SPI_InitStructure); // SPI1 enable SPI_Cmd(SPI1,ENABLE); GPIO_ResetBits (GPIOE, GPIO_Pin_12); SpiDelay(10); while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE)==RESET); SPI_WriteByte(0x0f); while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE)==RESET); SPI_WriteByte(0xff); SpiDelay(10); GPIO_SetBits (GPIOE, GPIO_Pin_12); |
11个回答
楼主把2个波形都抓一下.如果不用反相器的情况下,可以正常通讯是吗?
慢慢调吧,时序的问题很头疼
只能抓波形比较了
关键程序SPI_WriteByte 没贴出来,别人怎么帮你?
不懂帮顶
不懂帮顶 ,
还是抓波形认真分析一下
你好,如果实在调不出来,你可以用STM32CubeMx来配置一下SPI,然后自动生成代码,看一下官方自动生成的代码是怎么配置的,我以前的经验,你代码中:
SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //SPI_NSS_Hard SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB 部分配置的有问题,先从最基本的入手。 在抓波形的时候,一定要保证有数据在SPI上传输,不然看不到波形的 |
有不是库函数的吗?
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; 数据长度是8位,改成16位
STM32串口接受中断使用C++STL中的queue导致所有中断失效
4028 浏览 1 评论
2772 浏览 0 评论
STM32配合可编程加密芯片SMEC88ST的防抄板加密方案设计
1293 浏览 0 评论
3622 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
3436 浏览 4 评论
GMT+8, 2025-2-4 11:59 , Processed in 0.687542 second(s), Total 58, Slave 53 queries .
