嗨,
在安装和编译iNemo库之后,我想知道是否有 与M1模块相关的代码示例,甚至是简单的。 谢谢 #inemo-M1-样本代码 以上来自于谷歌翻译 以下为原文 Hi, after installing and compiling the iNemo Libraries, I wanted to know if there are any code samples relating the M1 module, even simple ones. Thank you #inemo-m1-sample-code |
你好,
我仍然没有任何示例代码可以发布到论坛上,但我会在不久的将来发布一个示例代码供您参考。 同时,如果您有任何问题或需要支持,请随时与我们联系。 谢谢, 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello, I still do not have any sample codes to post onto the forum, but I will work on having one posted for your reference in the near future. In the mean time, feel free to contact us in case you have any questions or need support. Thank you, Thiago Reis |
你好Thiago
我非常感谢ST中的某个人似乎对iNemo软件感兴趣。 我想重申自1月份以来一直没有答复的问题,希望你能提供帮助: 你好, 在分析EKF预测状态时,在iNemo Engine Lite版本1.2.0(FW V.2.3.0)中我得出的结论是,四元数更新不使用传递给iNemo_PropagateP的pMat_Fsys定义的相同数学函数。 如果我是正确的,这似乎不是卡尔曼滤波器的正确实现。 因此,我有几个问题: 1- iNemo Engine Lite实施是否正确(如果没有,是否有计划的更新)? 2-更一般地说,我在哪里可以找到iNemo引擎的描述,提供有关实际实施的详细信息,例如:其中包括iNemo Lite引擎卡尔曼滤波器设计中使用的数学模型的描述? 谢谢 杰拉德 以上来自于谷歌翻译 以下为原文 Hello Thiago I very much appreciate that someone in ST seems to be interested in iNemo software. I would like to reiterate my questions that remained unanswered since January in the hope you can help: Hello, In the iNemo Engine Lite Version 1.2.0 (FW V.2.3.0) when analizing the EKF Prediction state I came to the conclusion that the quaternion update is not using the same mathematical function defined by the pMat_Fsys that is passed to the iNemo_PropagateP. If I am correct this does not seem to be a proper implementation of a Kalman filter. Thus I have a few questions: 1- Is the iNemo Engine Lite implemetation correct (and if not is there an update planned any time soon)? 2- More generaly speaking where can I find a description of the iNemo Engine providing details on the actual implementation, e.g. including, among others, the description of the mathematical model used in the iNemo Lite Engine Kalman filter design? Thanks Gerard |
2895 浏览 1 评论
3283 浏览 1 评论
1864 浏览 1 评论
3715 浏览 6 评论
6130 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
414浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
514浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
339浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
247浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
356浏览 2评论
GMT+8, 2025-3-5 07:01 , Processed in 1.045951 second(s), Total 49, Slave 43 queries .
