亲爱的大家,
这是我读取spi数据的代码: uint8_t ti_TDC1000_SPIByteReadReg(uint8_t addr) { uint8_t read_byte,inst; uint8_t dummy = 0x00; inst = TDC1000_READ_BIT&地址; //读取时确保bit6为0 // GPIO_ResetBits(TI_TDC1000_CSn_PORT,TI_TDC1000_CSn_PIN); // CS enablewhile(SPI_GetFlagStatus(SPI1,SPI_FLAG_TXE)== RESET); SPI_SendData(SPI1,inst); while(SPI_GetFlagStatus(SPI1,SPI_FLAG_TXE)== RESET); SPI_SendData(SPI1,dummy); / *等待接收一个字节* / while(SPI_GetFlagStatus(SPI1,SPI_FLAG_RXNE)== RESET); / *返回从SPI总线读取的字节* / read_byte = SPI_ReceiveData(SPI1);返回read_byte; } 我使用示波器,看到数据读取= 0x45,但在我的代码中 read_byte alway = 0xFF,我认为当spi收到数据时出错了。 以上来自于谷歌翻译 以下为原文 Dear all, here is my code to read spi data: uint8_t TI_TDC1000_SPIByteReadReg(uint8_t addr) { uint8_t read_byte,inst; uint8_t dummy = 0x00; inst = TDC1000_READ_BIT & addr; // for read make sure bit6 is 0 //GPIO_ResetBits(TI_TDC1000_CSn_PORT ,TI_TDC1000_CSn_PIN); // CS enablewhile (SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE)== RESET); SPI_SendData(SPI1, inst);while (SPI_GetFlagStatus(SPI1, SPI_FLAG_TXE)== RESET); SPI_SendData(SPI1, dummy); /* Wait to receive a byte */ while (SPI_GetFlagStatus(SPI1, SPI_FLAG_RXNE) == RESET); /* Return the byte read from the SPI bus */ read_byte = SPI_ReceiveData(SPI1);return read_byte; } I using oscilloscope and see that the data is read = 0x45, but in my code read_byte alway = 0xFF, I think somewhere wrong when spi recieve data. |
4个回答
更改等待RXNE的等待事件。
当TXE置位时,SPI刚刚开始吐出字节(并且可以预先加载新的字节) 设置RXNE时,整个字节已经发货,一个已经到达读取。 您可以切换GPIO以查看何时发生与要调试的SPI时钟相关的每个等待时间。 以上来自于谷歌翻译 以下为原文 Change the wait events for waiting for RXNE. When TXE is set, the SPI is just starting to spit the byte out (and a new one can be pre-loaded) When RXNE is set the whole byte has been shipped and one has arrived for reading. You can toggle a GPIO to view when each wait happens respective to the SPI Clocks to debug. |
嗨,
我收到GPIO并看到SPI_FLAG_RXNE = SET收到所有数据后,我认为这是正确的吗? 你能告诉我这个bug我必须解决的问题吗? “ 更改等待RXNE的等待事件。 “我应该改变什么?谢谢 以上来自于谷歌翻译 以下为原文 Hi, I toogle GPIO and see SPI_FLAG_RXNE = SET after recieved all data, I think that is correct? Could you suggest me what i must fix with this bug? ' Change the wait events for waiting for RXNE. ' what should I change?Thanks |
尝试通过RXNE标志测试替换所有TXE标志测试,看看会发生什么。
以上来自于谷歌翻译 以下为原文 Try replacing all the TXE flag test by RXNE flag test and see what happens. |
2906 浏览 1 评论
3290 浏览 1 评论
1870 浏览 1 评论
3724 浏览 6 评论
6134 浏览 21 评论
GMT+8, 2025-3-9 10:00 , Processed in 1.385972 second(s), Total 82, Slave 66 queries .
