你好
我正在使用LSM330DL并且两个传感器数据都具有400Hz ODR,并使用SPI协议将此数据读取到PIC MCU。 我当前正在使用STATUS_REG寄存器并轮询ZYXDA位以确定新数据是否可用,然后我读取OUT_寄存器。这个解决方案的问题是我不断轮询传感器,这会耗费大量电流。 我需要的是保持传感器和MCU处于低功耗/睡眠模式,并有一个中断(DRDY?)向MCU发出可用的新数据信号,因此MCU将唤醒,并从OUT_寄存器读取数据,然后继续回到睡眠模式。 在我看来,LSM的两个传感器读数都是对齐的(如果我错了,请纠正我),所以我认为我只需要一个中断信号用于任一传感器,然后从两者读取数据。 我应该如何设置和配置LSM以获得中断,以通知MCU新数据可用? 请注意,应用程序不是运动检测,而是400Hz采样,无论是否发生运动 #lsm330dl #sampling #ddy-interrupt 以上来自于谷歌翻译 以下为原文 Hello I'm using a LSM330DL and have at 400Hz ODR of the both sensors data, and read this data to a PIC MCU using SPI protocol. I'm currently using the STATUS_REG register and poll the ZYXDA bit to determine if new data is available, and then I read the OUT_ registers. The problem of this solution is I'm continously polling the sensor and this consumes a lot of current. What I need is to keep both sensors and MCU in low power / sleepmode, and have a interrupt (DRDY?) to signal the MCU of new data available, so MCU will wake up, and read the data from the OUT_ registers, and go back to sleep mode. It seems to me that both sensors readings of the LSM are aligned (correct me if I'm wrong), so I thought that I only need one interrupt signal for either sensor, and then read the data from both. How should I setup and configure the LSM in order to get an interrupt to signal the MCU that new data is available? Please note that the application is NOT motion detection, but 400Hz sampling, regardless motion occurred or not #lsm330dl #sampling #drdy-interrupt |
我和丹尼尔有同样的问题,我只是在数据表中没有看到任何澄清这一点。
以上来自于谷歌翻译 以下为原文 I have the same question as Daniel, I'm just not seeing anything clarifying this in the datasheet. |
2895 浏览 1 评论
3283 浏览 1 评论
1864 浏览 1 评论
3715 浏览 6 评论
6130 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
414浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
514浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
339浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
247浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
356浏览 2评论
GMT+8, 2025-3-5 09:53 , Processed in 1.028374 second(s), Total 42, Slave 37 queries .
