喜
配置LIS3DSH的状态机后,我无法获得中断。你能给我一些例子吗?我的代码如下: LIS3DSH_Write_Byte(CTRL_REG1,(u8)0x01); //使能SM1,SM1中断路由到INT1 LIS3DSH_Write_Byte(CTRL_REG3,(u8)0x48); //中断信号有效高电平,中断锁定,INT1信号使能 LIS3DSH_Write_Byte(CTRL_REG4,(u8)0x57); //启用X,Y,Z,ODR = 50 Hz。 LIS3DSH_Write_Byte(CTRL_REG5,(u8)0x00); //滤波器带宽800 Hz,+ / - 2g,禁用自检 LIS3DSH_Write_Byte(tiM3_1,(u8)20); // Timer3 1000ms LIS3DSH_Write_Byte(ST1_0,TI3); // SM1状态1 LIS3DSH_Write_Byte(ST1_1,CONT); // SM1状态2 #tech 以上来自于谷歌翻译 以下为原文 hi, I can't get the interrupt after configuring the state machine of LIS3DSH. Could you give me some examples. My code as following: LIS3DSH_Write_Byte(CTRL_REG1, (u8)0x01);//enable SM1, SM1 interrupt routed to INT1 LIS3DSH_Write_Byte(CTRL_REG3, (u8)0x48);//Interrupt signal active HIGH, Interrupt locked, INT1 signal enabled LIS3DSH_Write_Byte(CTRL_REG4, (u8)0x57);//X, Y, Z enabled, ODR = 50 Hz. LIS3DSH_Write_Byte(CTRL_REG5, (u8)0x00);//filter bandwidth 800 Hz, +/-2g, Self-test Disabled LIS3DSH_Write_Byte(TIM3_1, (u8)20);//Timer3 1000ms LIS3DSH_Write_Byte(ST1_0, TI3);//SM1 state 1 LIS3DSH_Write_Byte(ST1_1, CONT);//SM1 state 2 #tech |
我不记得定时器是否引起了中断,我不这么认为。我记得这个加速度计有一个设置,默认情况下禁用,当达到停止或继续状态时会导致中断,也许你可以启用它,看看当它到达那个状态时是否会弹出中断。看着你:
4.34 此外,您可以通过将数据就绪中断和Fifo设置为流模式或任何其他中断(fifo full等)来检查中断是否实际有效。我个人遇到了一些问题,没有收到断线和中断,但加速度计工作正常。 以上来自于谷歌翻译 以下为原文 I don't remember if the timer caused an interrupt, I don't think so. I recall this accelerometer had a setting, by default disabled, that caused an interrupt when reaching an stop or continue state, maybe you could enable this and see if the interrupt pops when it reaches that state. Looked it for you: 4.34 Also, you could check that the interrupt actually works by setting the Data Ready interrupt and Fifo to stream mode, or any other interrupt (fifo full, etc). I've personally had some problems with broken traces and interrupts not being received but the accelerometer was working ok. |
2893 浏览 1 评论
3282 浏览 1 评论
1863 浏览 1 评论
3714 浏览 6 评论
6129 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
414浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
513浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
339浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
247浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
356浏览 2评论
GMT+8, 2025-3-5 00:03 , Processed in 0.983973 second(s), Total 42, Slave 37 queries .
