大家好,
我正在开始一个新的夏季POC项目,并构建和部署一个新的RDS平台。 硬件将是运行Windows Server 2016 TP5的Dell Blade M630服务器。 他们将安装RDS会话主机角色。 微软称服务器2016现在允许使用硬件gpus,而无需安装虚拟机管理程序。 您只需要设置组策略以在remotefx部分下启用硬件gpu。 这对我们的环境来说是个好消息,因为我们的用法最适合会话桌面。 Nvidia M6网卡能否通过会话桌面将高清视频用于最终用户瘦客户端设备? 理想情况下,这些将是安装了多媒体编解码器包的Igel UD6机器,但我们也将使用mstsc.exe测试Windows 10 1511客户端。 谢谢, 格伦。 以上来自于谷歌翻译 以下为原文 Hi all, I'm starting a new summer POC project building and deploying a new RDS platform. Hardware will be Dell Blade M630 servers running Windows Server 2016 TP5. They will have the RDS Session Host role installed. Microsoft state that server 2016 now allows the use of hardware gpus without the need to install a hypervisor. You just need to set the group policy to enable hardware gpu under the remotefx section. This is great news for our environment were our usage is best suited to session desktops. Would an Nvidia M6 Grid card enable the use of HD video through the session desktop to an end user thin client device? Ideally these will be Igel UD6 machines with the multimedia codec pack installed, however we will also be testing out Windows 10 1511 clients with mstsc.exe. Thanks, Glen. |
4个回答
目前我们不支持Server 2016,因为它是未发布的产品。
您可以使用最新的驱动程序对其进行评估,但不保证性能,我们无法提供帮助。 目前,在“裸机”部署中,M60或M6都不受支持。 虽然我无法提供Dell刀片的具体详细信息,但未来可能会提供对此功能的支持。 根据服务器2012 R2 RemoteFX会话,只要您具有端到端的完整RemoteFX连接,您就可以从硬件加速中受益。 您将受益多少取决于应用程序以及它是否将利用GPU进行视频加速。 一般而言,大多数组织都受益于GPU,从而降低了CPU开销。 以上来自于谷歌翻译 以下为原文 Currently we do not support Server 2016 as it is an unreleased product. You can evaluate it with the latest drivers, but there's no guarantee of performance and we cannot provide assistance. At present neither the M60 or the M6 are supported in "bare metal" deployments. Support for this functionality may be available in the future though I can't provide specific details for the Dell blade. As per server 2012 R2 RemoteFX sessions, as long as you have a full RemoteFX connection end to end then you will benefit from hardware acceleration. How much you'll benefit by depends on the application and whether it will utilise the GPU for video acceleration. Generally speaking though, most organisations benefit from the GPU leading to a reduction in CPU overhead. |
谢谢Jason的回复,
你能推荐一款裸机支持的显卡吗? 理想情况下,适合M630刀片服务器。 我见过用于M630的Mezz插槽的Quadro K5100M 8GB。 虽然这些驱动程序似乎只支持Windows 8 64bit,但我听说它可以在2012 R2上运行。 以上来自于谷歌翻译 以下为原文 Thanks for the reply Jason, Can you recommend a graphics card which is supported on bare metal please. Ideally, one which fits an M630 blade server. I have seen the Quadro K5100M 8GB which comes in a Mezz slot for the M630. Whilst the drivers only seem to support Windows 8 64bit, I have heard it will work on 2012 R2. |
我希望能够使用最新的驱动程序评估2016年,但它们不会安装。
如果我的客户已经向我询问有关Citrix和图形应用程序的服务器2016和K1卡的问题,那么有一个早期发布驱动程序进行测试会很不错。 以上来自于谷歌翻译 以下为原文 I would like to be able to evaluate 2016 with the latest drivers, but they do not install. It would be nice to have an early release driver to test as I have customers that are already asking me about server 2016 and K1 card for Citrix and graphics applications. |
GRID 4.0版本详细介绍了M6 / K1 / K2可用的裸机支持,包括RemoteFX选项:https://griddownloads.nvidia.com/flex/GRID_4_Products_Support_Matrix.pdf
以上来自于谷歌翻译 以下为原文 The GRID 4.0 release details the bare metal support available for M6/K1/K2 here including RemoteFX options: https://griddownloads.nvidia.com/flex/GRID_4_Product_Support_Matrix.pdf |
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3272 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3702 浏览 4 评论
GMT+8, 2025-7-6 04:04 , Processed in 0.545519 second(s), Total 49, Slave 43 queries .
