你好,先生,
有没有任何文件描述CYW54 907的节电? 我只找到一些带有CYW43907的文件。 谢谢您。 以上来自于百度翻译 以下为原文 hi Sir, Are there any document describes the power saving with CYW54907? I only find some documents with CYW43907. thank you. |
4个回答
此处连接的CYW43907/CYW54 907产品指南的功耗文件可用于CYW43907和CYW54 907。
以上来自于百度翻译 以下为原文 The power consumption document linked here off the CYW43907/CYW54907 Product Guide can be leveraged for both the CYW43907 and CYW54907. |
你好,先生, 谢谢你的回复。 我还有另一个关于省电设置的问题。 我可以在SDKX文件夹 43xxx Wi-Fi中找到相对的例子 我想知道我能用CYW54 907这样的应用程序代码吗? 以上来自于百度翻译 以下为原文 hi Sir, thanks for your reply. I have another question about the power saving setting. I can find the relative example at SDK_FOLDER43xxx-Wi-Fi And i want to know can i use such app code for CYW54907? |
您可以在SDK中检查Test.PosiLoT或Test.AppsYEnter(43XXXY Wi-Fi/Apps/Test/AppSySt入睡)应用程序。对于帮助文档中提到的54907,用法将相同。 以上来自于百度翻译 以下为原文 You can check test.powersave or test.apps_sleep (43xxx_Wi-Fi/apps/test/apps_sleep) application inside SDK. Usage will be the same for 54907 as mentioned in the help document |
WiFi和处理器省电有不同的机制。例如,查看具有高度遍历API的PSM和PSM。
使用这些API显著降低了板的能耗。 还要注意的是,CYW板包括其他消耗电力的东西。因此,如果你正在寻找的话,你可能无法达到非常低的功耗。 以上来自于百度翻译 以下为原文 There are different mechanisms for wifi and processor power saving. For example, look into PSM and PSM with high throughout APIs. Using these APIs significantly reduce the energy consumption of the board. Also note that the CYW board includes other stuff that consume power. Therefore you might not be able to reach a very low power consumption if that is what you are looking for. |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
273浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 12:32 , Processed in 0.666034 second(s), Total 49, Slave 44 queries .
