问候语,
我有一个Δ∑ADC连接到多路复用器,用于采样三个信号。我得到两个信号正确,但第三信号通道似乎相当嘈杂。下面我附上了一张显示ADC读数的图片。红色读数是第三通道,比其他读数更嘈杂。所有通道都是差动的,并且连接到从4(2)到4(7)的引脚。ADC转换率为42000 SPS。 有没有建议如何减少第三声道的噪音?为什么一个频道中的噪声比其他频道多? 也有一些时候我在所有频道都有毛病。原因何在?下面还附有一个斑点的图像。 谢谢您。 美国国家石油公司 48.4 K 1nChn更多噪声 62.9 K 以上来自于百度翻译 以下为原文 Greetings, I have a delta sigma ADC connected to mux for sampling three signals. I get two signals correctly but the third signal channel seems to be quite noisy. Below i have attached an image showing the ADC reading. The reading in red color is third channel and is more noisy than others. All channels are differential and connected to pins from 4[2] to 4[7]. ADC conversion rate is 42000sps. Is there any suggestion how to reduce the noise in third channel? Why there is noise more in one channel compare to other channels? Also some times i get glitch in all the channels. What could be the reason for it? An image of glitches is also attached below. Thank you.
15个回答
如何发布您的项目文件,然后通过点击create_workspace_bundle和附着在一个新的评论。也让我们看看你的示意图。
以上来自于百度翻译 以下为原文 How about posting your project by clicking on File then Create_WorkSpace_bundle and attaching it to a new comment. Also lets see your schematic. |
我怀疑串扰到一些相邻的数字引脚。尝试移动到另一组引脚并查看结果。
ODISSEY1 以上来自于百度翻译 以下为原文 I suspect a crosstalk to some adjacent digital pin. Try to move to another set of pins and see the result. /odissey1 |
你好, 我试着用其他一组别针,但它有很大的帮助。还有一件事我观察到,当我把ADC引脚连接到传感器时,调试器在PSoC板上发光,甚至没有给PSoC供电。为什么会这样?我怎样才能避免这种情况呢?我怀疑它可能会损害我的PSoC。 谢谢您。 以上来自于百度翻译 以下为原文 hi, i tried with other set of pins but it dint help much. One more thing i observed that when i connect the adc pins to sensor, debugger led on PSoC board lights up even without powering PSoC. Why is it so? How can i avoid this? I suspect it can potentially damage my PSoC. Thank you. |
望望Ll 发表于 2018-9-27 16:05 是的,你可以破坏PSoC。你可能有一个接地回路。 断开PSoC板上的所有传感器,并确保蓝色LED不活动。 然后短ADC输入1-3(带有电阻器),并检查没有观察到ADC噪声。 也张贴传感器的示意图,这将有助于(PNG/JPG,而不是完整的项目)。 ODISSEY1 以上来自于百度翻译 以下为原文 Yes you can damage PSoC. You probably have a ground loop. Disconnect all sensors from PSoC board and make sure that blue LED is not active. Then short ADC inputs 1-3 ( with resistors) and check that no ADC noise observed. Also post the schematic of the sensor, that will help (png/jpg, not full project). /odissey1 |
另一件事,你应该使用恒星地面。这意味着所有的理由都是连接到同一place.without彼此任何距离。
以上来自于百度翻译 以下为原文 One other thing you should be using a Star Ground. That means all of the grounds are connected to same place.without any distance from each other. |
通道CHYEXM是开放的,它没有指定的PIN。
以上来自于百度翻译 以下为原文 Channel Ch_EXm is open it has no assigned pin. |
是的,所有的场地都连接到同一个地方。的ch_exm是无关的,但我认为不应该影响其他渠道阅读。我也读了那个频道然后把它扔掉了。 谢谢您。 以上来自于百度翻译 以下为原文 Yes, all grounds were connected to same place. The Ch_EXm is unconnected, but i think that should not affect other channels reading. Also i just read that channel and discard it. Thank you. |
nvwuwy 发表于 2018-9-27 16:11 你好, 我所连接的传感器是一个quadcell(https://www.thorlabs.com/drawings/338563b2dc83dd4f-a4cd8da6-ea77-8e3d-fe2d31014dc1b8f8/pdq80a-specsheet.pdf)。它给模拟输出电压,我试图通过阅读ADC。 我试着做空的ADC输入但我得到的峰值输出而不是零阅读如下所示。 谢谢您。 以上来自于百度翻译 以下为原文 hello, The sensor what i am connecting is a quadcell (https://www.thorlabs.com/drawings/338563b2dc83dd4f-A4CD8DA6-EA77-8E3D-FE2D31014DC1B8F8/PDQ80A-SpecSheet.pdf ). It gives analog output voltage which i am trying to read through ADC. I tried shorting adc inputs but i get spikes in output instead of zero reading as shown below. Thank you. |
望望Ll 发表于 2018-9-27 17:08 您的链接有一个错误,我无法查看传感器上的信息。你也试过其他模拟多路复用器组件吗? 以上来自于百度翻译 以下为原文 Your link has an error and I was unable to view the information on the sensor. Also have you tried other Analog mux components? |
你使用的是什么版本的Psoc Creator? 以上来自于百度翻译 以下为原文 What version of Psoc Creator are you using? |
这里是HTTPS://www. thabab.com /thultual.CFM?零件编号=PDQ80A 其他MUX我还没试过,但我还是弄不清楚这个问题。我正在使用PSoC创建者4.1。 谢谢您。 以上来自于百度翻译 以下为原文 Here it is https://www.thorlabs.com/thorproduct.cfm?partnumber=PDQ80A Other mux i haven't tried, but i still couldnot figure out the problem. I am using PSoC creator 4.1. Thank you. |
PDQ80A的输出电压范围±2 Vmin。 必须有一个级别匹配方案。 以上来自于百度翻译 以下为原文 The PDQ80A has an Output Voltage Range of ± 2 Vmin You must have a level matching scheme. |
这很可能并不适用,因为你指定的引脚是不同的,但它的症状类似的一个问题,我有。因此,记录:
如果你使用的cy8c58lp处理器模块,采用销P15 [ 7 ]作为一个ADC输入噪声时,我看到了很多。然后我发现在文档,R18在模块的背面是不使用时,p15 [ 7 ]帽上移除。噪音消失了。 以上来自于百度翻译 以下为原文 This most likely doesn't apply because the pins you've assigned are different, but the symptoms are similar to an issue I had. So for the record: If you're using the CY8C58LP processor module, when using pin P15[7] as an ADC input I saw a lot of noise. I then found in the documentation that R18 on the back of the module is to be removed when not using P15[7] for cap sense. Noise gone. |
你用这个工具包吗?
CY8CKIT-050 PSoC®5LP开发包 以上来自于百度翻译 以下为原文 Are you using this kit CY8CKIT-050 PSoC® 5LP Development Kit |
不,我使用FieleSCO2,CY8C588AXI-LP096设备。 以上来自于百度翻译 以下为原文 No i am using freesoc2, CY8C5888AXI-lp096 device. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 09:58 , Processed in 1.209028 second(s), Total 103, Slave 87 queries .
