你好,
我试图整合SPI NVRAM组件,我收集的是上个月新的。我在我的项目中使用了基于AN89665的先前版本,但是在最近的创建者更新中,这个版本现在有问题了。按照CE219174中的说明,在项目依赖项下,我被要求“点击新条目(用户依赖项),并从NvRAMORIGUTCONTRONETLIB CYLB文件夹中选择NVRAMUA组件LIB CYPRJ”。我没有这个项目或文件夹在我的系统,并已搜索如何获得它,到目前为止已经失败。我认为我已经收集到了CY8CKIT-042最新的软件安装的一部分,所以我安装了,但仍然没有运气。我可能会得到这个奖,但请帮助。谢谢! 以上来自于百度翻译 以下为原文 Hi there, I'm trying to integrate the SPI NVRAM component, which I gather is new this past month. I was using the prior version based on AN89659 in my project, but in recent Creator updates, that version is now problematic. Following the instructions in CE219174, Under Project Dependencies, I'm asked to "Click on New Entry (User Dependencies) and Select NVRAM_Component_Lib.cyprj from NVRAM_Component_Lib.cylib Folder". I do not have this project or folder on my system, and have searched for how to get it, and thus far have failed. I thought I had gleaned that is part of the latest software install for CY8CKIT-042, so I installed that, but still no luck. I'll probably get the boob award for this, but please help. Thanks! |
嗨,戴夫,
请访问下面的链接 HTTP://www. CyPress .COM/DICONTION/APPLION-NOTES/AN8969-接口SPI-F RAM-PSOC-4 你需要从这个链接下载“PSoC4YNVRAMYSPI.zip”文件夹。它包含了这个项目。一旦你做到这一点,你就能够在PSoC创建者中使用NVSRAM组件。 谢谢, 普拉迪普塔 以上来自于百度翻译 以下为原文 Hi Dave, Please visit the link below http://www.cypress.com/documentation/application-notes/an89659-interfacing-spi-f-ram-psoc-4 You need to download the "PSoC4_NVRAM_SPI.zip" folder from this link. It contains the project. Once you do it you will be able to use the nvSRAM component in the PSoC creator. Thanks, Pradipta. |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
571浏览 2评论
424浏览 2评论
437浏览 2评论
384浏览 2评论
916浏览 2评论
GMT+8, 2024-12-24 10:57 , Processed in 1.105020 second(s), Total 75, Slave 59 queries .
